Results 1 to 22 of 22
Thread: CEL w/ APR stage 2 and downpipe?
  1. Member FastB7S4's Avatar
    Mar 28th, 2008
    ChesCo, PA; Charlotte, NC
    12 CC Lux Ltd, 11 Touareg Sport, 11 328i, 02 4Runner SR5
    07-23-2012 05:52 AM #1
    So I just had an APR downpipe installed and software upgraded to stage 2 by APR themselves at Waterfest. After reflash, I see the check engine light come on. I tell the guy and he clears it and says all is fine and "it's just the cluster." The drive home was uneventful. After being home for a little, I decided to make sure I was on the right program. I wasn't and was on 91 instead of 93 so I switched. This morning, on the drive to work, the CEL comes on. What gives? I thought the flash is supposed to take care of that? What an inconvenience. Now I prob have to drive to an APR dealer an hour and a half away to get it checked out.
    OEM+ | APRll | CARBONIO | H&R | Eibach
    Mar 8th, 2006
    Dallas, TX
    2010 CC Sport
    07-23-2012 09:39 AM #2
    Go to AutoZone or O'Reilly; they can tell you why the cel is there and what's causing it. It's free too
  3. Member airmax1's Avatar
    Dec 7th, 2008
    Atlanta
    2012 VW CC 2.0T DSG
    07-23-2012 09:47 AM #3
    Happened the same with me, APR need to download stage II+....I tough that they learned the lesson by now. You need to drive to APR dealer waste time and $, they will pull out your ECU and fixed for you.
    2012CC2.0LTSI DSG CW/35%Tint/Neuspeed HI-FLOTop&Turbo Discharge/APR3"DP/APRCarbonioSTGI/LotsVAG-COMdone/EuroStyleTurn Signal/StopTech Cryo-SportStop Drilled Rotors F&R/HawkHPSF&R/H&RSportSpringSet/Debadged/USP8000KDigitalHIDkit/AWEDV/Borla CT/Hartmann HTT-256-GA:M-Conti 235/35ZR19DW/APR FMIC/Black G2 Brake Caliper/DR 8mm/F/Hotchkis27mmRSB/InteriorLEDKit/APR KO4+UNITRONIC STG II DSG/R8Coilpacks&NGK-PFR7B/
  4. Member FastB7S4's Avatar
    Mar 28th, 2008
    07-23-2012 09:56 AM #4
    Quote Originally Posted by i29gtaylor View Post
    Good idea. Wouldn't hurt to know what the code is.
    Quote Originally Posted by airmax1 View Post
    I know. So inconvenient. I'm hoping APR will pick up the tab if the shop charges me anything. Hope it's just as easy as another reflash. Stage 2+ you say?
  5. Member FastB7S4's Avatar
    Mar 28th, 2008
    07-23-2012 09:58 AM #5
    Oh, and they didn't pull my ECU (2012) again like I thought they would. They said that since I already had stage 1 software, they can just reflash through the port. I thought that was odd.
  6. Member
    May 5th, 2012
    Worcester, MA
    2010 CC Lux DSG, 2012 Ram 1500 Big Horn
    07-23-2012 10:05 AM #6
    same thing happened to me on my drive back home from waterfest. check engine light went on and when i got hope i cleared it and then next day it came back on.
    i got a stage 2 intake downpipe and flash done at the waterfest
  7. Member airmax1's Avatar
    Dec 7th, 2008
    Atlanta
    2012 VW CC 2.0T DSG
    07-23-2012 11:11 AM #7
    Is not just a port reflesh, on a 2012 they NEED to pull the ECU.
  8. Member FastB7S4's Avatar
    Mar 28th, 2008
    07-23-2012 08:02 PM #8
    Went to Autozone and had them scan the code - PO420, deficient catalyst or something like that. Definitely O2 sensor related.
    Other than the CEL, I'm very impressed and happy with the DP and software upgrade. The car just jumps.
  9. Member airmax1's Avatar
    Dec 7th, 2008
    Atlanta
    2012 VW CC 2.0T DSG
    07-24-2012 02:37 PM #9
    Quote Originally Posted by FastB7S4 View Post
    HAHA when they are going to upgrade to stage II+ it will not jump or sound that mean anymore good luck to you.
  10. Member FastB7S4's Avatar
    Mar 28th, 2008
    07-24-2012 02:45 PM #10
    really? damn! i like how it sounds and the car is really responsive.
    I asked about the stage 2+ thing and was told that all files are labeled 2+. Hoping it's just the wrong tune. My VW tech friend told me to inquire if they have a test pipe file.
  11. Member airmax1's Avatar
    Dec 7th, 2008
    Atlanta
    2012 VW CC 2.0T DSG
    07-24-2012 02:56 PM #11
    Classic APR answer.... Not sure if your VW friend is going in the right direction.
    May 5th, 2012
    Worcester, MA
    07-24-2012 04:06 PM #12
    i went to auto zone today and got the same code
    how did u contact tthem? i send them an email couple of days ago and no response yet.
  13. Member FastB7S4's Avatar
    Mar 28th, 2008
    07-24-2012 10:52 PM #13
    Quote Originally Posted by ciki View Post
    I emailed them through their website and also IM'ed one of their guys here on Vortex. There's a thread here that they advertised their Waterfest specials. This one. I just IM'ed the guy that posted it. I've been going back and forth with him. He asked for my VIN today so he can see what files were flashed.
    Today, I received a response to the email through the website. It was from the guy I dealt with when I called to set up my Waterfest appointment. I basically told him the situation and he said that it was something that they will take care of. Hopefully, he's not just saying that. I'm calling my local APR dealer tomorrow and making an appointment for them to look at it.
    When you contact them, just explain your situation. I think the key is to be respectful and not a douchebag so you don't turn them off.
  14. Member
    May 5th, 2012
    Worcester, MA
    07-26-2012 12:34 AM #14
    they emailed me asking to contact my apr dealer. i dont know when i will be able to see him because i work 7 days a week
  15. Member Gradysmith's Avatar
    Feb 17th, 2012
    Charlotte, NC
    2012 VW CC R-line
    07-30-2012 09:52 PM #15
    Sounds like APR loaded the ECU with the "non test pipe file". This will cause the CEL to come on. If you bought the fault code erase option, it's easy to clear, but will come back on in a day or so. You need the "test pipe file", which turns off the CAT O2 sensor so to speak. If your state requires emission testing, the "test pipe file" will not pass because they will see that the sensor for CAT efficiency is turned off, or "not ready".
    APR K04 | APR Carbonio Stage I & II CAI | APR downpipe | APR intercooler | DSG | 40% tint | VWR sport springs | Hotchkis 27mm RSB
  16. Member FastB7S4's Avatar
    Mar 28th, 2008
    07-30-2012 10:48 PM #16
    Quote Originally Posted by Gradysmith View Post
    Yep, that's exactly what happened. They had the test pipe file disabled when I was flashed. I've also been told the same thing about emissions. My state does require emissions testing so I have to figure out a way to pass. My tech friend says that I only need one of the 2 checks to come back as "ready." Maybe if I install o2 sensor spacers?
  17. Member
    May 5th, 2012
    Worcester, MA
    08-01-2012 05:06 PM #17
    does anyone know if these o2 sensor spacers will remove the cel. i dont want to go with the test file route because i want to pass emisions.
    but, it this is the only way i was thinking what if i have the test file removed before i go for the sticker and clear the check engine light right before they take my car in. that would suck a bit because i would have to go to the apr dealer and put the file back in.
  18. Member FastB7S4's Avatar
    Mar 28th, 2008
    08-01-2012 05:10 PM #18
    I just talked to the guy at my local APR dealer and he said that some venders do turn off the o2 sensor like mentioned above to remove the CEL. When tested, the sensor will send back an error of "not ready" or something like that which causes you to fail emissions. He said that this is not the case with APR and that the sensor remains on. He said that since our 12 CCs are new, he doesn't think we should have a problem with emissions. The CEL will be off and the sensor will still be on and will return a status of "ready." Hope he's right.
  19. Member
    May 5th, 2012
    Worcester, MA
    08-01-2012 05:47 PM #19
    lets hope it works with 2010
  20. Member
    May 5th, 2012
    Worcester, MA
    08-07-2012 05:15 PM #20
    i got this fixed yesterday
    loaded stage 2+ and the cel is gone !!
    and my ecu had to be pulled again
  21. Member airmax1's Avatar
    Dec 7th, 2008
    Atlanta
    2012 VW CC 2.0T DSG
    08-07-2012 05:39 PM #21
    Amazing...
  22. Member FastB7S4's Avatar
    Mar 28th, 2008
    08-07-2012 11:10 PM #22
    I had the test pipe file added on Sat. They didn't pull the ECU, though. So far so good. No CEL.
