Results 1 to 3 of 3
Thread: Squeaky front control arm bushings, month after lowering.
  1. Member AngeloM3's Avatar
    May 11th, 2011
    Rhode Island
    '06 Jetta 2.5L
    07-23-2012 08:55 AM #1
    So for the past couple weeks I've had this squeaking in the front when reversing and slowly moving forward... happens when going over bumps.
    Brought it into a shop over the weekend and they said it was the front control arm bushings. They loosened the bolt, greased it up, tightened it back down.
    Now my MKV was lowered on coilovers about a month ago, has about 1k miles on the coilovers. At first I had them spun all the way down (with everything in)... didn't make any noise then. Since then I've adjusted so I wasn't so low... that's when the squeaking started.
    Anyone ever experience this? Only way to fix = replace bushings?
  2. Junior Member OneTruMag's Avatar
    Feb 4th, 2012
    Dallas, TX
    TT 225Q Rdstrs: 2002 & 2003
    07-26-2012 09:18 AM #2
    My tech says urethane bushings will squeak. Convinced me to go with good rubber.
    Sent from my Skyrocket using Tapatalk 2
    "Funk is its own reward" -- Parliament
  3. Member Goheels555's Avatar
    Feb 9th, 2010
    North Carolina
    2013 Candy White GTI
    08-20-2012 06:41 PM #3
    when i had my old vr6 slammed I experienced some bad squeaking after I hit the control arm on a bump. I didnt realize it but the control arm bent right where it is connected to the sub frame and was squeaking every time it moved. All I had to do was hammer out the dent and it went away. I hope yours is as simple, meanwhile im onto a new mk4 with new suspension issues Good luck!
    2013 on AMG Monoblocks
    Quote Originally Posted by anthonyjimenezvw View Post
    ps. dont be a douchebag
