Results 1 to 2 of 2
Thread: FS/FT Bagged 05 GLI on 3 Piece Works
  1. Member dubcreeping's Avatar
    Mar 16th, 2008
    cumberland md
    2005 pg gli
    07-23-2012 09:55 AM #1
    SOLD
    Exterior:
    Hood notch filled
    Euro front rub
    Chrome molding blacked out
    Black mirror caps
    OEM HID Reps
    30% tint
    Badgeless Grille Painted Gloss Black
    Motor:
    Powder Coated Valve Cover
    Powder Coated Intake Mani, (I guess you could say it's shaved too, I sanded all the numbers and stuff off but you can't tell cause it's under, I have pics though)
    Evolution Motorsports Short Ram Intake
    Forge Motorsport TIP
    Forge Motorsport DV
    Forge Motorsport Block off plate used for the SAI, EVAP, n249 delete
    Neuspeed underdrive pulleys
    "j" Valve
    GIAC Chip
    MILTEK TURBO BACK EXHAUST
    Deleted Coolant ball and installed filler neck
    Deleted windshield washer fluid
    B&M Short Shifter
    Water pump and timing belt were change at 56,000 miles
    Brakes:
    ECS Drilled and Slotted Rotors
    Suspension:
    full analog management kit from bagriders
    airlift slam series xl's up front
    airlift performance series in the rear with bilstein sport shocks
    polished 5 gallon aluminum tank
    viair dual 400 compressors
    3/8 air line to bags
    notched frame
    avs black switchbox
    Skid plate by evolution import
    Interior:
    Visors and Sunroof Motor Cover wrapped in DC Shoe fabric
    The Bad:
    CEL is on from the SAI, EVAP, n249 delete for improper flow.
    Wheels:
    Work Equip Anhelos
    17x8 and 17x9.5
    Falken 512's
    on to the pictures
    By kingvr at 2012-07-23
  2. Member dubcreeping's Avatar
    Mar 16th, 2008
    cumberland md
    2005 pg gli
    07-24-2012 08:49 AM #2
    Bump
