VWVortex.com - Reverse won't engage
    Results 1 to 14 of 14
    Thread: Reverse won't engage
      Aug 5th, 2010
      Shippensburg, Pa
      1999.5 A4
      07-23-2012 09:38 PM #1
      Hello I just scooped up a 1999 audi a4 1.8t quattro, only problem is reverse won't engage. The shifter will go back like its getting ready to go to reverse just will not engage which leads me to think that reverse is still there but something is wrong. Any thoughts?
    2. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      D2 S8, B5 A4 V8
      07-24-2012 06:23 AM #2
      Does it go in to all the other gears ok, particularly 5th?
      My A6 does the same thing occasionally so I just lift the clutch in neutral and try again and that usually sorts it.
      Throw an Audi engineer down a hole with a ladder and he will fashion a shovel from it and tunnel his way out
      Quote Originally Posted by shwak23 View Post
      You could always call your insurance and say that some vandals tried to swap your car to rwd while you weren't looking.
      Aug 5th, 2010
      Shippensburg, Pa
      1999.5 A4
      07-24-2012 04:32 PM #3
      Yeah it goes into all other gears just fine..
    4. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      D2 S8, B5 A4 V8
      07-24-2012 05:09 PM #4
      Not shifter alignment then.
      Have you tried double-clutching it to see if that helps?
      Dec 19th, 2011
      92626 (Orange County, CA)
      2001.5 Audi A4 1.8TQM
      07-24-2012 05:49 PM #5
      This might be a silly question, but have you tried pushing down, and then going into reverse? If your car is pre-facelift (1999.0 as opposed to 1999.5) then you'll have reverse lockout that requires you to push down on the shifter before entering the reverse gear.
      2001.5 A4 1.8TQM: VAG-COM, F21, Motoza 750cc E85/91 tune, 034 3" HFC, 2.5" exhaust, FMIC, Eibach coilovers, 034 rear sway bar, A8/TT & S4 brakes, JHM shifter & linkage upgrades, single mass flywheel/clutch, 4:1 diff mod, E-fan, Apikol diff mount, AWE DTS, 034 catch can, Nexus 7 HU, custom sound system & subwoofer, sport cloth seats, BiXenon retrofit
    6. Member
      Aug 5th, 2010
      Shippensburg, Pa
      1999.5 A4
      07-24-2012 05:53 PM #6
      Have been pushing down and have not tried double clutching..gonna sound like a noob but that's when you clutch to get out of gear disengage then push clutch back in to go back in gear correct?
      Dec 19th, 2011
      07-24-2012 05:56 PM #7
      Quote Originally Posted by ZDespreaux View Post
      That's right.
      Aug 5th, 2010
      Shippensburg, Pa
      1999.5 A4
      07-24-2012 05:58 PM #8
      Quote Originally Posted by MetalMan1 View Post
      That's right.
      Would it matter if the car is on or not?
    9. 08-03-2012 04:47 PM #9
      Any news on the situation? I am thinking about buying a 99 a4 for $1000 with the same problem.
    10. Member
      Aug 5th, 2010
      Shippensburg, Pa
      1999.5 A4
      08-04-2012 04:58 PM #10
      Quote Originally Posted by Itsmrgreen View Post
      Going to try to reset the syncros and if that doesn't work just get them rebuilt shouldn't be too expensive. And I would buy the car if you can..you can part it out for more than that.
    11. Junior Member
      Jan 6th, 2012
      mass
      08-06-2012 11:27 AM #11
      mine wont engage unless the car is off, but i have trouble with 1st and 2nd , mainly second at high rpms, the kid told me his shift linkage is a little bent but still sounds fishy
      Aug 5th, 2010
      Shippensburg, Pa
      1999.5 A4
      08-06-2012 09:45 PM #12
      Quote Originally Posted by myates3089 View Post
      Hmm Idk mine won't engage at all comes close and if I hold the shifter back you can hear it rubbing but I don't have any problems with any other gears.
    13. Member d15nonvtec's Avatar
      Dec 18th, 2006
      PA
      08-07-2012 12:30 AM #13
      Once in awhile mine won't go into reverse, but I go back to neutral, then clutch again and it'll go in just fine. Perhaps a minor alignment issue, but my other gears are fine. Bushings maybe?
    14. Member
      Aug 5th, 2010
      Shippensburg, Pa
      1999.5 A4
      08-07-2012 10:41 PM #14
      Quote Originally Posted by d15nonvtec View Post
      Yeah maybe.
