Results 1 to 8 of 8
Thread: Audi 3A block, ABA head. Compression ratio?
  1. 07-23-2012 11:06 PM #1
    I'm putting an ABA head on a 3A block.
    Anyone know what the resulting compression ratio will be?
    If it's high like 10 or 11:1, what is best way to get it down?
    Stack MLS gaskets or use a head spacer?
    If just gaskets, how many?
  2. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    07-24-2012 12:05 AM #2
    I don't know what the 3A head looks like, but if it is anything like the other 8V counterflow heads, the CR should be near the same as stock.
    FS:Sunroof Deflector
  3. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    1992 Corrado ABA and MS3-Pro powered, 84 Honda V65 Sabre
    07-25-2012 08:37 AM #3
    Quote Originally Posted by mk1vw View Post
    What's stock compression on a 3A? how many cc's is the stock 3A head?
    The Professor
    Melbourne, FL
    92 Corrado OBD2 ABA Powered by MS3Pro
    M & L EFI Performance
  4. 07-25-2012 10:49 AM #4
    comp is 10.5:1 according to this:
    http://www.not2fast.com/vw/stuff/vw_engines.shtml
    can't find info on 3A chamber size.
    i don't have the equipment or experience to cc the chamber, piston dish and quench area of my combo.
    guess with just keep looking.
  5. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    07-25-2012 12:51 PM #5
    If the info in the link is correct a 3A with an ABA head will wind up about 10 to 1 maybe a touch lower.
    The Professor
    Melbourne, FL
  6. 07-25-2012 03:59 PM #6
    so then with one of these
    http://www.bahnbrenner.com/vw_audi/p...ead_Gasket_ABA
    I should be good for 15psi intercooled and megasquirted with 30lb injectors?
  7. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    07-25-2012 05:51 PM #7
    Yeah that will work. That set up is good for ~ 225-250whp then you run out of injector.
    The Professor
    Melbourne, FL
  8. 07-25-2012 10:51 PM #8
    that's cool.
    this will be plenty in a MK2 Golf.
    pushing the limits of the 020 at that point anyway.
