Results 1 to 13 of 13
Thread: ABA + 1.8 Motor owners
  1. Member mtbrob's Avatar
    Oct 9th, 2009
    Vancouver BC 98230
    88 fox, 05 Jetta tdi, 96 Passat tdi
    07-24-2012 01:54 AM #1
    We have a oil problem in the race Fox, it has been pushing oil out into the catch can by the quart, and I need some advice. It looks like any oil over 4ltrs ends up in the catch can. But here is the thing, we run the 93 turbo diesel oil filter(it's almost double the size of stock) and if stock oil capacity is 4.5 what gives? When the oil is halfway to the add oil bend in the dipstick it pushes out no oil.
    We run the ABA with the 1.8 head, stock valve cover and TT block-off plate with a 3/4 inch breather hose fitted into it. It has new rings and all the oil breathers lead to the catch can.
    Any thoughts would help.
    7th overall and 1st in class this weekend at 24hours of LeMons
  2. 07-27-2012 07:13 PM #2
    If you check pistons, block, and other mechanical parts and all is ok, maybe your problem is pre-ignition. You know how is engine racing temperature?
    Fox oil pan is baffled?
    What´s the fuel injection model you use?
    What is the fuel?
    The termostatic valve is out?
  3. Member Banned wagon's Avatar
    Mar 3rd, 2004
    2013 Model S P85s Outback 89 4Runner 90&89 fox wagons 89 4door fox 89 2Door GL Fox
    07-27-2012 07:25 PM #3
    Awesome! Job at the northworst GP ! Was a good battle for the class C win!
    Good luck in class B (or higher) next time
    Come down to thunderhlll again I want some bacon sandwiches
  4. Member mtbrob's Avatar
    Oct 9th, 2009
    Vancouver BC 98230
    07-28-2012 02:03 AM #4
    WGC
    Pistons good, rings good, block good and pre-ignition maybe.
    109deg.
    We run stock CIS-E -
    a windage tray, no baffles...... yet.
    Thermostat in - temp I don't know.
    I'd take any advice.
    Right now the plan is to have a catch can return line go to the pan and put a oil temp plug in the pan as well.
    Feb 14th, 2007
    Allentown PA
    1993 VW Fox 1994 Chevy S-10
    07-28-2012 12:15 PM #5
    Nevermind
  6. Member oRANGEJULIUS's Avatar
    Jul 29th, 2006
    VW: Fox, Passat Trucks: f350, 2500hd Other: J body
    07-29-2012 10:28 PM #6
    Just a thought: is your outlet on the TT block off plate baffled in any way (baffle plates, screen, etc)? I know most crankcase vents have some sort of baffle system in order to minimize the amount of oil being discharged yet still allowing the vapor/pressure to escape.
  7. Member mtbrob's Avatar
    Oct 9th, 2009
    Vancouver BC 98230
    08-02-2012 02:29 AM #7
    The block off plate has a 3/4 inch hose fitting that runs up to the catch can. Inside the catch can there is a baffle. The can is up hill of the block off plate and the valve cover.
    We run 91 octane fuel.
    Baffles in the pan before we race again, I think.
    The funny thing to me was, with the breather/filter off the catch can you could feel the air being pushed out puff puff, like a steam engine, puff puff.
  8. Member dacolino's Avatar
    May 31st, 2002
    Hawthorne, NJ
    1985 Ford Mustang GT, 1989 GTi 16v, 1988 Fox GL wagon, 02 Suzuki SV650
    08-14-2012 02:34 AM #8
    Quote Originally Posted by mtbrob View Post
    Stock oil capacity is less than 4.5qt? All the foxes I own(ed) take around 3.8qt, do you mean with the diesel filter?
    You mention a breather out of the crank block off plate...this might be your issue. I could have sworn reading the 8v technical forum a while back someone was having a similar issue and turned out that oil was just blowing right through there instead of acting as a breather. Just curious why are you running a crank and valve cover breather?
    Feb 14th, 2007
    Allentown PA
    08-14-2012 07:21 AM #9
    Quote Originally Posted by dacolino View Post
    I was thinking the same thing, but then remembered he has an ABA 2.0, not the 1.8. The ABA oil capacity is 4.2-4.3 quarts. With a bigger filter he should be right around 4.5 quarts.
  10. Member mtbrob's Avatar
    Oct 9th, 2009
    Vancouver BC 98230
    08-15-2012 02:42 AM #10
    We added a breather to the block off plate because we were pushing so much oil out the valve cover.
  11. Member QuantumSyncro's Avatar
    Apr 28th, 2000
    Des Moines, IA
    97 Jetta TDI, 89 Fox diesel, 92 300SD turbo, 82 GS1100E
    08-15-2012 11:51 PM #11
    Quote Originally Posted by Edcon91 II View Post
    engine makes no difference, the constraint is the oil pan, so your original thoughts were correct IF it has a stock 1.8 oil pan you would still have to abide by the oil capacity of the 1.8L engine, otherwise the level is too high.
    diesel 1.6 takes just under 4 qt with new filter, same jumbo filter he's probably running. Turbo D is the same situation, same pan but has oil return line...same capacity.
    edit:
    Reference 1983 VW Quantum owners manual for 4 cyl engine gas, oil change with filter takes 3.5 qt oil, without takes 3 qt oil. Oil change for 5 cyl and diesel takes 4.0 qt with filter and 3.5 without.
    steve
    Gir - "won't the sploding hurt?" Zim - "Silence!"
  12. Member denver_fox's Avatar
    Oct 15th, 2011
    Denver, Colorado
    93 gl 4dr---93 2dr---88 gl wagon---79 Jimmy
    08-16-2012 11:15 PM #12
    Hmmmm, interesting. My new wagon pretty much has the same setup-albeit the catch can and crank-block off plate. Oil doesnt "push" past my valve cover... but I'm not racing it. It does has a slight leak though, right up front by the intake and cam gear. The PO said it just needed new cam-seals.
    Oh, and the wagon has the stock 1.8 pan as well, along with stock oil filter. Maybe that is your problem, too much oil pressure...
  13. Member mtbrob's Avatar
    Oct 9th, 2009
    Vancouver BC 98230
    08-20-2012 05:51 PM #13
    So I drained the oil yesterday and there was only 3 liters in there. Damn we raced for at least 4 hours on that much oil.
    I pulled the pan and welded in a fitting for a return line from the catch can.
    On a happy note I pulled and cut open the oil filter and there was no debris.
