Results 1 to 8 of 8
Thread: exhaust manifold
  1. Junior Member
    May 29th, 2012
    Pennsylvania
    1983 Rabbit GTI and 2009 Jetta TDI
    07-24-2012 05:38 PM #1
    So i have a 1983 rabbit gti and the exhaust manifold on it is cracked and so in my search of finding a new one a friend of mine offered to sell me a full engine, now I know this is an older engine but i know it is a 1.8 8v so i was happy i got it for $100 but when i took a look at the exhaust manifold it was different it had an O2 sensor i believe and the end was round not square so you can bolt the exhaust pipe on. Now what are your thoughts on this? Could this be a mk2 engine or what i will post pics. I am in desperate need for help.
  2. Junior Member
    May 29th, 2012
    Pennsylvania
    07-24-2012 05:54 PM #2
    Here are some pics of it.
    [url]http://s756.photobucket.com/albums/xx204/ianwags/?action=view&current=IMG_0696.jpg
    http://s756.photobucket.com/albums/x...3DIMG_0698.jpg
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    07-25-2012 01:17 AM #3
    Yuck, toilet bowl. Good a time as any to upgrade to a dual outlet manifold / downpipe
    I really suck at smog.
  4. Junior Member
    May 29th, 2012
    Pennsylvania
    07-25-2012 10:04 AM #4
    Yeah I would love to buti don't have that kinda money and I will get one when I rebuild this new engine. Would this manifold still work on my 83 and how the heck do I get the pipe to fit in? Also is there any telling as to what year or so this new engine I just bought is?
    Nov 17th, 2001
    Northern Wisconsin
    07-25-2012 12:05 PM #5
    The engine code might help you find a year range for the $100 engine. With that exhaust system the engine is likely a MK 2 engine. The code should be on the engine just above and to the left of the distributor where the head and block join. The first two letters on the engine plate should be something like GX, RD or RV.
    The only way to use the pictured manifold would be to come up with a "toilet bowl" downpipe. Those downpipes often came with the cat attached. I would think that it would be just as easy to find an appropriate manifold in a junkyard. I don't know if an exhaust shop could weld on a different fitting or the costs involved in doing so.
    Having said all that -- you could also purchase an appropriate header system that would bolt up to replace the leaky manifold. FR
  6. Junior Member
    May 29th, 2012
    Pennsylvania
    07-25-2012 12:20 PM #6
    mk1 and mk2’s are virtually identical correct because i would like to rebuild and possibly turbo the $100 one.
  7. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    07-25-2012 05:32 PM #7
    mkII downpipe will not fit a mkI car. I think there were some toilet bowl combos on mkI cars, I have seen one on a pickup. Best bet would be to find a diesel manifold or any early mkI dual outlet mani w/ or w/o the O2 sensor.
    FS:Sunroof Deflector
  8. Junior Member
    May 29th, 2012
    Pennsylvania
    07-25-2012 06:04 PM #8
    from where the manifold ends down is all going to be custom made and custom welded cause i already have a borla 2.5 on the car.
