VWVortex.com - Parking brake fault
    Page 2 of 2 FirstFirst 12
    Results 26 to 49 of 49
    Thread: Parking brake fault
    1. 09-08-2012 09:39 PM #26
      These are the only two faults currently:
      Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
      Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
      Component: Bordnetz-SG H54 2202
      Revision: 00H54000 Serial number: 01000007491286
      Coding: 80849F0340041A00470000000F0000000009FB434600010000 0000000000
      Shop #: WSC 05124 123 12345
      VCID: 71E96C8A68DD7690DEB
      Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
      Component: Wischer 180707 003 0205
      Coding: 00046997
      Shop #: WSC 05124
      1 Fault Found:
      02390 - Control / Regulation for Ambience Lighting (E400)
      009 - Open or Short to Ground
      Freeze Frame:
      Fault Status: 01101001
      Fault Priority: 5
      Fault Frequency: 1
      Reset counter: 159
      Mileage: 109038 km
      Time Indication: 0
      Date: 2012.08.09
      Time: 08:14:00
      Freeze Frame:
      ON
      Voltage: 12.30 V
      ON
      ON
      OFF
      OFF
      OFF
      __________________________________________________ ________________________________
      Address 53: Parking Brake Labels: 5N0-907-801.clb
      Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
      Component: J540 EPB3 VW-09393 0009
      Revision: 008 Serial number: 00000000147454
      Coding: 0000057
      Shop #: WSC 05311 000 00000
      VCID: 295944EA808D4E5056B
      1 Fault Found:
      03200 - Switch for Electric Parking Brake (E538)
      012 - Electrical Fault in Circuit - Intermittent
      Freeze Frame:
      Fault Status: 00111100
      Fault Priority: 1
      Fault Frequency: 15
      Reset counter: 198
      Mileage: 110139 km
      Time Indication: 0
      Date: 2012.08.19
      Time: 07:00:03
      Freeze Frame:
      Voltage: 14.20 V
      Count: 10
      Speed: 0.0 km/h
      Hex Value: 0x1161
      Hex Value: 0x0001
      Hex Value: 0x0808
      May 8th, 2012
      New York City
      Passat 08 jetta 01 jetta 98 240sx
      09-08-2012 09:59 PM #27
      Quote Originally Posted by Sandman333 View Post
      I posted over in the Vag-Com forum. The error found was electrical in the parking brake switch circuit. Possible I got a bad switch as a replacement? Could it be that my rear pads are so worn that this is causing the error (70K miles on them and they are near the end of their life. I have new ones here)?
      70k miles on those pads? What?
      Dealer replaced mines at 30k miles!7
      Sent from my DROID2 using Tapatalk
      DO YOU SPEAK DAS AUTO?
    3. 09-08-2012 11:43 PM #28
      Quote Originally Posted by EVANGELIONHD View Post
      Yep, almost. Last trip to the dealer for recalls they recommended replacing them. I bought this car new and have just shy of 69,200 on her now, so I rounded up. The remaining pad would certainly make it another 800 miles anyway. Maybe they lasted so long because it's a MT? Less braking because of downshifting and no braking against the engine at low speeds like an AT. Front brake pad thickness is still near new.
      Sent from my DROID RAZR MAXX using Tapatalk 2
    4. Member SickTRed08FSI's Avatar
      Apr 28th, 2011
      Syracuse, NY
      08 Passat 2.0T, 11 Volvo XC60 R Design
      09-09-2012 05:25 AM #29
      Had this fault show up once the other day, and havent seen since. Im surprised this is covered by a TSB since its a known issue. Anyone else had problems with door latches?
      #fukur2cnts
      Detail Johnny - Serving the Greater Syracuse area
      Sep 17th, 2007
      PA
      '07 Passat Wagon
      09-09-2012 07:30 AM #30
      I had my parking brake do the same thing as you describe... switch was replaced by dealer at no cost under CPO at about 60K.
    6. 09-09-2012 09:09 AM #31
      Quote Originally Posted by N715DP View Post
      I've already replaced the switch though.
      Mar 10th, 2009
      2006 Passat 2.0t 6mt
      09-09-2012 11:40 AM #32
      I got 62k out my rear pads of my 6mt 2.0t. I am a little curious if the parking brake button is VW OEM deal since you got it from overseas. If it OEM VW part and switch is revision C version then this throws a bit of wrench in my idea.
    8. 09-09-2012 12:40 PM #33
      Quote Originally Posted by Boosted2003! View Post
      It looked like the real part, but didn't have the actual VW/AUDI marking on it like the factory part. That's probably the problem.
      Old vs new pads:
      Now to beat the frozen rotor off the hub.....
      Mar 10th, 2009
      09-09-2012 02:02 PM #34
      Old vs new pads:
      Is that about 3-5mm left on old pads?
    10. 09-09-2012 06:17 PM #35
      Probably. That's the outside pad. The inside is a little thinner. I think the dealer said they were 2mm. Didn't get the swap done as I don't have a 14mm triple square here. Have to order it, no local tool stores carry them...
      Still couldn't get the rotor to budge (yes I removed the torx screw). Sprayed it down with penetrating oil and then made sure to get it off the rotor surface with brake parts cleaner before I put the old pads back on.
    11. Member
      Mar 10th, 2009
      09-09-2012 10:06 PM #36
      If your replacing the rotors just knock them with a hammer gently. lol
    12. 09-10-2012 06:20 AM #37
      Oh I tapped them, more than gently. Didn't budge. Penetrating oil will have a couple days to soak and I'll get my sledge out. New rotors already here.
    13. Junior Member
      Sep 10th, 2008
      TN
      2007 2.0T 6MT 2013 2.5 SEL-Premium
      10-04-2012 08:09 PM #38
      Sandman - where did you get the pads and rotors and how much? I have an '07 6MT and replaced my rears at 51k and am still on the fronts at 85K. Am hoping to get to 100k and will do fronts and prob rears again as well. I imagine this time I should do rotors, right?
      Thanks
    14. n00b
      Oct 5th, 2012
      SL,UT
      2011 Passat CC 6 speed MT
      10-05-2012 07:39 PM #39
      My 06 Passat started having the same Parking Break error. When I put the key in the ignition and try to release the parking break it comes up with an error, after I take the key out and put it back in it fixes the problem for a few days and then the error will come back.
      I have done a little research and as I have seen on here, replacing the Parking Break Switch should fix the problem. Has it fixed the problem for anyone that has had the same issue?
    15. Member Defex's Avatar
      Nov 20th, 2010
      Croatia
      07 Passat 2.0TDI DSG Highline
      10-06-2012 02:21 AM #40
      I had my switch replaced 5 days ago after an error, it wouldn't engage then one day decided to start working. .
      I took it to the dealer as I had to replace my rear pads anyway, they didn't come up with another reason. All seems fine now
    16. n00b
      Oct 5th, 2012
      SL,UT
      10-07-2012 06:56 PM #41
      Thanks for the comment, my break pads are still in good condition. Did the switch stop working before or after you replaced it?
    17. 11-22-2012 11:46 AM #42
      Sorry I didn't get back to this thread- missed the subscription button so I didn't know there were replies. I went with the Blauparts U-Slot kit: http://www.blauparts.com/proddetail....d=D2B1139-01-G
      That's the front. The rear kit is less than $90 for pads and rotors. After the anti-rust coating wore off the brake feel and stopping power is much improved. That's really saying something, since it's the rear brakes. The front should make a bigger difference, but since I still have 2/3 of my front pads left and no rotor warp at 73K miles, I'm not changing the fronts just yet. Hopefully the anti-rust coating does its job- hate looking at rusty rotors behind my wheels.
      The brake fault warning has happened a few more times. It seems every time I open and close the parking brakes with Vag-Com, the fault goes away for a while. I still suspect it might be because the parking brake motors are reaching the limit of their travel because the pads were so worn down. Now that I have new pads and rotors installed, I will know for sure if the problem returns or stays away completely. Time will tell.
    18. 11-25-2012 08:58 AM #43
      New rotors look good behind the wheels and braking power is impressive.
      Sent from my DROID RAZR using Tapatalk 2
    19. n00b
      Feb 17th, 2016
      Virginia
      06 VW PASSAT 2.0T
      02-17-2016 08:49 PM #44
      I need help with my VW. I dont know alot about VW but what i do know thus far it is expensive. My parking brake light is blinking and beeping as long as it's in motion. The blinking i can handle its the beeping thats killing me. I tried every brake fuse and all work fine. I tried disconnecting the battery and even doing the positive negative touch. Nothing. The parking sensor in the dash works just fine so its not that either. I have to go to VW and get a VW rim tool to take my tire off. ($45.00) Im going to try and clean the parking motor on the caliper and see if that works. If it doesn't then what? Please i need help!!!!!!!
    20. 07-01-2016 04:46 PM #45
      Quote Originally Posted by Tynitty757 View Post
      I have been having the same issue with my 06' Passat. The parking break works fine but the lights on the dash keeps going on and beeping when i drive it is very annoying. I just switched the Parking break sensor/switch for a new one and still the same issues.
      does anyone know how I can fix this? Please HELP!
      Thanks!
    21. 12-28-2016 11:23 AM #46
      Tynitty
      Did you ever resolve this issue ? My guess is you replaced the switch. I have the same issue and am trying to get that noise to shut off....
    22. Member randyvr6's Avatar
      Aug 17th, 1999
      2012 CC R Line, 2007 Passat Wagon, 2001 Jetta VR6, 1993 Corrado SLC, 1973 Ford Capri
      12-29-2016 11:55 PM #47
      When I had the problem, I first replaced the switch, but that wasn't the issue. I ended up having to replace the rear calipers. The left one went bad a few years ago, and the right side last year. Took me quite awhile to get the right side to stop displaying the error even after I replaced it. If you buy a caliper, they are sold both with and without the parking brake motor, so make sure you order one with the motor
      Once I fixed the issue, I took it to the dealer to get the parking brake module software updated per a TSB I found just in case that would help in the future. I don't ever use the parking brake other than the automatic cycle that is done every few weeks to set the pad distance
    23. 01-18-2017 02:43 AM #48
      Replaced my switch and it solved my parking brake faults.
      Sent from my XT1585 using Tapatalk
    24. Junior Member
      Dec 16th, 2007
      The Eastern Panhandle of West Virginia
      2008 Passat 3.6
      Yesterday 07:50 PM #49
      Just changed my parking brake switch. Easy. The dash light is still on and off. Erratic.
      Does anyone have more educational info for me. I can hear the brake motor. All the standard stuff has been done. BTW my B6 3.6 with 216,770 miles. Just replaced the front rotors. In reading some of the responses above, there is a parking brake motor that engages the rear brakes? If so, next step is the dealer.
      How many miles will the rear rotors last?
