Results 1 to 12 of 12
Thread: Idle boost valve
  1. Member sprocket007's Avatar
    Oct 14th, 2002
    Alberta, Canada
    '92Passat G60 Syncro, '90 G60 Corrado, '89 Cabriolet, '86 Jetta Coupe, '81 Rabbit LS '74 Westfalia.
    07-25-2012 04:37 AM #1
    Hello,
    I'm wanting to use a G60 valve cover on my '89 and I'm wondering what others have done with the associated vacc tubing to and from the idle boost valve to make it neat and tidy?
    I have the G60 valve cover with the single hole on the top driver side for "PCV" valve, I understand there is more than one style G60 cover.
    Suggestions?
    Thanks,
    W
    picture of the G60 valve cover
    BSc.N, EMS/FIRE
  2. Member sprocket007's Avatar
    Oct 14th, 2002
    Alberta, Canada
    07-25-2012 08:15 PM #2
    Can I delete? Cap the vacc line pre throttle body and cap the line going to the air box? If I do this will the car stall frequently? And of course some sort of breather on the valve cover...
    BSc.N, EMS/FIRE
  3. Member sprocket007's Avatar
    Oct 14th, 2002
    Alberta, Canada
    07-28-2012 03:24 PM #3
    Can I see pictures of what others have done?
    BSc.N, EMS/FIRE
  4. Member sprocket007's Avatar
    Oct 14th, 2002
    Alberta, Canada
    08-01-2012 02:04 AM #4
    no pictures?
    BSc.N, EMS/FIRE
  5. Member sprocket007's Avatar
    Oct 14th, 2002
    Alberta, Canada
    08-05-2012 04:20 AM #5
    Any pictures or suggestions?
    BSc.N, EMS/FIRE
    Nov 13th, 2010
    Tacoma
    1987 Cabriolet
    08-05-2012 05:25 AM #6
    I got rid of mine by blocking off various lines, but this might be what you are looking for. http://forums.vwvortex.com/showthrea...ight=pic+heavy
  7. Member sprocket007's Avatar
    Oct 14th, 2002
    Alberta, Canada
    08-05-2012 11:52 AM #7
    that helped a bit
    BSc.N, EMS/FIRE
  8. Member sprocket007's Avatar
    Oct 14th, 2002
    Alberta, Canada
    08-06-2012 08:37 PM #8
    DEGS
    How does it run? do you find you have stalling issues?
    Picture of your set up?
    BSc.N, EMS/FIRE
    Nov 13th, 2010
    Tacoma
    1987 Cabriolet
    08-06-2012 09:14 PM #9
    My car runs good, I didn't really notice a difference. I'm no expert or anything on those valves though, or any of this vacuum bull****. Mine use to have A/C, but that might be irrelevant. So anyway I circled where I closed off the lines.
    Photobucket
  10. Member sprocket007's Avatar
    Oct 14th, 2002
    Alberta, Canada
    08-06-2012 09:26 PM #10
    thanks for your info.
    Im also changing my cam at the same time so in changing a few things at once im cautious if i do have issues i wanna know where to look. between the cam and idle boost delete.
    W
    BSc.N, EMS/FIRE
  11. Member sprocket007's Avatar
    Oct 14th, 2002
    Alberta, Canada
    08-08-2012 08:01 AM #11
    annnyyoone??
    BSc.N, EMS/FIRE
  12. Member sprocket007's Avatar
    Oct 14th, 2002
    Alberta, Canada
    08-16-2012 01:56 AM #12
    well since I have gotten virtually no reply to this...
    I'll let you know how this works for me.
    I have my new cam and gear, painted G60 valve cover....
    BSc.N, EMS/FIRE
