Results 1 to 8 of 8
Thread: Air conditioning problems
  1. Member Bthasht's Avatar
    Oct 6th, 2011
    757 VA
    2009 VW CC
    07-25-2012 11:11 AM #1
    So here's the deal. 09 VW CC with 2.0tsi motor 51,000 miles. My ac was not blowing cold anymore so i put a can of r134 with stop leak into the system. Blew colder for about a week. Then nothing. All hot air coming from vents. Ran for over 15 min on way home blowing hot air and turned off car in driveway. Freon blew out of compressor blow by valve. Replaced high pressure switch still no ac. Any input?
    Sent from the tip of my fingers using tapatalk
  2. Member bigred35's Avatar
    Mar 10th, 2002
    Yorba Linda
    2012 GTI 4Door DSG and 2011 Ducati 848 Evo Stealth
    07-25-2012 04:19 PM #2
    On my MK5 GTI, I have 4 compressors and 3 total AC systems replaced.
    They are not using quality components for these systems any longer.
    Sorry to hear about yours!
    Sean
  3. Junior Member bmllr8's Avatar
    May 18th, 2012
    Charleston, SC
    2012 GLI
    07-25-2012 07:21 PM #3
    The stop leak crap can mess up the expansion valve. Its great if you are trying to give someone else a turd by trading in your car, otherwise its a gamble. Good luck.
  4. Member Bthasht's Avatar
    Oct 6th, 2011
    757 VA
    2009 VW CC
    07-25-2012 07:36 PM #4
    Quote Originally Posted by bmllr8 View Post
    Very usefull post there. Thank you very much. I got the gauge set and vacuum pump to extract all remaining r134. Then will be filling with fresh r134. I will look into expansion valve replacement next.
  5. Junior Member bmllr8's Avatar
    May 18th, 2012
    Charleston, SC
    2012 GLI
    07-25-2012 07:43 PM #5
    Adding your own refrigerant is fine as long as you realize its going to leak out again eventually. If you can find the refrigerant with UV or other dyes that can help you locate the leak, then go for it. Just stay away from the plug a leak stuff.
  6. Member Nvturbo's Avatar
    Oct 2nd, 2011
    N. Carolina
    2012 CW GTI 4dr DSG
    07-28-2012 05:08 PM #6
    It's probably the same issue I had on my '12 GTI......the clamp on the hose going into the AC compressor (closest to the throttle body rubber coupling) causing a hole in the hose itself.
    '12 VW GTI sunroof/conv package
  7. 08-04-2012 12:53 AM #7
    Similar situation here. Mine would blow somewhat cold, and then intermittently blow warm/hot air. I grabbed a gauge at work one day to see what it read, and it was a tad low. Took it to my buddy who has a shop, he evacuated my system and recharged it to spec, **** blew like an icebox that day, later that week it was almost back to the same ****, haven't put a gauge on it yet though to see if I've leaked yet. I will say it doesn't blow as hot, but has it's intermittent fluctuations of blowing nice and cold to somewhat warm.
  8. Junior Member bmllr8's Avatar
    May 18th, 2012
    Charleston, SC
    2012 GLI
    08-06-2012 09:58 PM #8
    More people against the fix a leak AC repair in a can. Really, don't do it.
    http://autorepair.about.com/b/2010/0...is-so-easy.htm
