Results 1 to 15 of 15
Thread: How to remove dash trim at windshield base
    May 28th, 2009
    Arlington, VA
    2009 JSW TDI; 2012 Passat TDI SEL
    07-25-2012 08:54 PM #1
    2012 B7: How is the long dashboard trim piece, at the base of the windshield, attached? I've got a lot of creaking between the main dash and this piece. The dealer has offered to put some foam pieces between the rubbing surfaces, but I'd like to know what's involved before I have someone tear the dash apart.
    Thanks.
  2. Member capclassicv2's Avatar
    Mar 2nd, 2007
    Maryland
    2012 VW Passat
    07-26-2012 06:15 AM #2
    I don't personally know how, but you should have faith in your dealer.
    CURRENT: 2012 VW Passat 2.5 SEL Premium
    PREVIOUS: 2009 VW Tiguan SE
    PREVIOUS: 2006 VW Passat 2.0T
    PREVIOUS: 1997 Oldsmobile Achieva
    May 28th, 2009
    Arlington, VA
    07-26-2012 06:43 AM #3
    Quote Originally Posted by capclassicv2 View Post
    I do, but because I'm very particular, I like to know exactly WHAT is being done before I hand over the key. If it's not too complicated, I'd rather do it myself.
  4. 07-26-2012 08:57 PM #4
    Quote Originally Posted by tdiatlast View Post
    I am almost 100% sure it is just a bunch of clips, You can always wait at the dealer for the work to be done on the car and request to sit in your car while it is being worked on. I know the techs don't really like to watched and hovered over but it's your car. I have done that and I still do that, but I was a service writer back in the day so I speak vw tech
    Current: 2012 VW Passat TDI SEL Premium
    Previous: '07 VW GTI 2.0T, '07 BMW K1200LT, '00 VW Golf 1.8T (4DRGTI), '92 GTI 2.0 16V, '04(2) Nissan Altima, '83 Rabbit GTI, '85 Golf GTI, '86 cabrio, '91 GTI 2.0 16V, '93 Passat VR6 and a couple others that I won't mention.
    My 2012 Passat TDI SEL Premium Fuelly Record
  5. 07-26-2012 08:58 PM #5
    Oh and report back once you see how it is done as I would like to know.
  6. Member
    May 28th, 2009
    Arlington, VA
    07-26-2012 10:50 PM #6
    Coffeemade, I'm disappointed in you. I thought for sure you would know how to do this!
    I won't have this taken care of for a couple of weeks, as there are too many household items that need my attention. Thanks for the advice to ride shotgun when the dash is dis-assembled. I'm trusting that John (tech) at Stohlman won't mind. Both he and Jack Smith (SA) have been very kind to me every time I drop in, and they're earning my trust.
  7. 07-27-2012 09:11 AM #7
    I have the same issue with creaking/cracking noise with that upper cheap plastic trim and would love to know how to remove it and add some sound dampening material. Please let us know if you discover how to remove it.
    Night Blue/Consilk Beige
  8. 08-02-2012 03:49 PM #8
    If you're talking about the thin long trim piece that sticks up above the dash that the tweeters covers are built into, it's REALLY easy to remove.
    The removal procedures:
    #1 pull up on trim piece
    #2 That's all.
    It's held in by little retainer clips, just pop them off, very easy to get in and out. Although, if your dealer is going to take care of it, why bother?
  9. 08-02-2012 04:22 PM #9
    I had mine in and the dealer couldn't recreate the cracking/creaking noise from there, but they said similar noise was coming from the headliner console and they sound deadened that area up. It has been better since then suprisingly. I'm always afraid to just pull on something to remove it, so I'm glad to hear it's that simply Should be easy to fix any sounds from there myself if I do have further issues with it. I've noticed the sound is worse when the interior temperature changes quite a bit (going from parked in the sun and using max ac, and it used to rattle more when it was colder our (meaning it had contracted in there). I don't know why they chose to use hard plastic there when the rest of the dash is the nice soft material that isn't so susceptible to expansion/contraction and rattling.
  10. Member
    May 28th, 2009
    Arlington, VA
    08-02-2012 10:46 PM #10
    Shapiro: Thanks for the advice. 3 clips? Advice on where they're located, and the type of clip?
  11. 08-02-2012 11:13 PM #11
    Ya know... I don't remember where they are located or even how many. I started out by popping off the tweeter cover with a small screw driver, this let me get my fingers under it from the inside (I think, it's been a while since I did it, I might have used something to pry it up from the inside). From there I carefully worked to the other side opting off one clip at a time. If you have to pry at all, be careful not to scratch anything, I used a cloth anywhere where I was prying to protect things.
    I don't even remember if they are the little metal clips that you can squeeze or the plastic piece with a knob on the end.
    If you need more help let me know and I will go pull it off again and give you better info. It really wasn't too difficult, just be careful you don't scratch anything, and make sure you are pulling up close to the clips so you don't break the trim piece. The hardest part about it was getting the trim piece out of the dash area once it was off... it is slightly wider than the width of the inside pillars, I had to kind of flex it while shoving one forward and outwards to get the other end out.
    May 28th, 2009
    Arlington, VA
    08-03-2012 08:37 AM #12
    Thanks. This sounds simple enough for the dealer, they've probably not done one yet, and maybe they'll let me watch. I was hoping the dash would not need to be disassembled.
  13. 08-06-2012 06:46 PM #13
    Bump for some pics at some point. The creak is annoying.
  14. Moderator
    Feb 2nd, 2006
    South Central KY
    2013 Passat TDI 2012 Passat S
    08-07-2012 09:14 PM #14
    info added to the DIY section
    If you can't take the HEAT be a COP
    2B1 ask 1
  15. Member compu_85's Avatar
    Aug 17th, 2004
    Springfield, VA
    08-11-2012 07:35 PM #15
    The trim simply pulls off. Getting it out from between the A pillars was more tricky than pulling it off the dash. I removed the speaker grilles first, they simply pull off as well (start on the inside corner closest to you).
    Here are some pictures with the trim removed:
    Big picture showing the trim. You can see the little tabs that engage the clips.
    -J
    1991 Mercedes 350SDL. 221,000 miles, 60k on the replacement motor
    1991 Jetta GL ECOdiesel. 429,000 miles. Totaled
    1992 Jetta GL ECOdiesel. 150,000 miles Sold.
    1999 Jetta "GLX" TDI. 282,000 miles.
    2012 Passat TDI SE DSG. 21,000 miles. LED tails, VCDS tweaks (wipers, alarm, cluster)
