#1
first of all what airbag generation is in the C5's? i was on ross-tech site diagnosing the problem and they mentioned different problems with different generation airbag systems.
so i don't know if is series of codes together is common in the A6 C5's but the car only has 87k on it and has never been in a wreck so i dont know why these airbag sensors are flipping out. ross-techs site mentioned some models malfunction and the codes are to be ignored?
here's the scan
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4B0 959 655 H
Component: Airbag Front+Seite 0002
Coding: 00106
Shop #: WSC 02325
VCID: 356525E725D1
4 Faults Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance too High - Intermittent
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
42-10 - Speed Deviation too High - Intermittent
