Yes, it will work fine. You will still need to do a few things depending on what you swapped when you did the VR. Namely, wiring up the blinker indicator plug (left and Right) that will come off of the A3 Cluster harness. ..unless you used the VR body harness too then you just need to plug it in![]()
