Results 1 to 6 of 6
Thread: How to setup ms1 v3.57 to run msd 6a
  1. Member TDiPusher19t's Avatar
    Feb 19th, 2007
    West Palm Beach, Fl
    1992 cabby aba 16vt(r.i.p.), 1989 gti , 1997 jetta tdi,83 gti 16vt
    07-26-2012 03:50 PM #1
    I'm in the process of switching over to pcb 3.57 and I cannot find online or on here how to setup the box to run an msd 6a. I set it up very easily on pcb 2.2, but I can't seem to find a write up for 3.57. I did however find one for pcb 3.0 but I don't think the setup for this board is the same. Is this something i just setup in the software settings?
  2. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    07-26-2012 04:19 PM #2
    It would be the same as the 3.0, just some of the jumper location descriptions change. They are functionally the same board.
    -Paul
  3. Member TDiPusher19t's Avatar
    Feb 19th, 2007
    West Palm Beach, Fl
    07-26-2012 04:52 PM #3
    So ive seen. I cannot seem to find r43 on the 3.57 board. The other step is to solder a 330 ohm resistor to the top of r26 then to IGBTIN with a wire. This all seems pretty straight forward, but the resistors on this board are tiny.
    http://www.msextra.com/doc/ms1extra/...ual.htm#msdout
    This is what im reading^
  4. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    07-26-2012 08:22 PM #4
    I dont think the v3 diagram is necessarily wrong but q16 isnt needed. Just use led jumper pad (pad1 on bottom row) to go to ign. That puts spark on pin 36. The rest pf the software settings are good.
    -Paul
  5. Member TDiPusher19t's Avatar
    Feb 19th, 2007
    West Palm Beach, Fl
    07-26-2012 08:43 PM #5
    so do i not put a connection between R26 and IGBTIN?
  6. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    07-26-2012 10:08 PM #6
    Nope just the pad it already has an led pullup. I was wrong jumper should be to igbtin and the jumpershould be on pins 1/2 of a removed q16.
    -Paul
