Results 1 to 6 of 6
Thread: O2C Gears Interchangable?
  1. Member -RalleyTuned-'s Avatar
    Nov 17th, 2008
    East of the Mountains, WA
    77' Rabbit 16v, '92 Passat Syncro Wagon1.8t
    07-26-2012 11:14 PM #1
    I am getting to the point where I am going to start upping the boost on my 1.8t setup. I have the boost control on and running well at 15psi and the engine/drivetrain has held up well for the past 5 years running 22-25psi with the previous owners.
    I am looking to get a set of gears as a backup in case the transmission in the syncro decides to grenade, is the gears out of a O2A/J interchangable with the O2C? Is there any fwd gears that are? I would ideally like to find gears that work and are similar if not the same, and get them cryo treated to hold a few more hp, without dropping the coin on a full custom set of gear haha
  2. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    07-28-2012 09:04 PM #2
    any 02a/02j gear will work.
    rather than treating the gears, you'll probably have better luck by adding a pinion brace.
  3. Member -RalleyTuned-'s Avatar
    Nov 17th, 2008
    07-28-2012 10:55 PM #3
    Open to anything really, I have always read the transmission, namely 3rd, start having issues over 300hp. We killed 3rd gear in our o2j in the rally car with only 190whp.
    Even just being able to replace the gears with something common is great news.
    Any details on the pinion brace?
  4. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    07-29-2012 12:56 AM #4
    gears break from casings flexing. So if you eliminate the casing flex, the gears dont break (or nearly as easy at least)
    VAP Motorsports sell a pinion brace, as does AP tuning. The upside/downside of the APtuning one is that you send them your housing, and they machine it so that the brace/cuff fits perfectly.
    check out the tech/drag racing forum, there is lots of tranny info on there.
    p.s. its TQ not HP that breaks things.
  5. Member -RalleyTuned-'s Avatar
    Nov 17th, 2008
    08-06-2012 08:15 PM #5
    Thank you for the tip, we ordered one for the Rally car straight away from USRT and got it installed, we are preparing for the Olympus rally so this was a welcomed upgrade! We have always had transmission issues, so hopefully the brace + the AP tuning gearset will keep us alive and running!
    Going to add this to my syncro the next time the transmission comes out, looking at an engine rebuild later this summer unfortunately
  6. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    08-06-2012 08:37 PM #6
    Quote Originally Posted by -RalleyTuned- View Post
    make sure that the shift fork doesnt hit it. If it does, you'll have throw out bearing problems.
