VWVortex.com - Fitting 9" wide on my 84 Q?
    Results 1 to 10 of 10
    Thread: Fitting 9" wide on my 84 Q?
    1. Member sambocs's Avatar
      Dec 12th, 2010
      southern NH
      92 Imported S4, 95 E320 wagon, MK6 TDI, Turbo Ducati M900, 79 KZ650, 99 Lifted XJ w/superswampers
      07-26-2012 11:22 PM #1
      Is the only way to know to buy them and try them? Does anyone know if 8-9 wide will fit on my 84 fwd quantum? 14x9 not sure the offset saw them on Craigslist the guy doesn't know. He send pictures of the measurements from the inside lip to where it would meet the rotor/drum. The 9s were around 5" and the 8s around 3" thanks guys.
      everythings for sale
    2. Junior Member skopek's Avatar
      Jun 16th, 2007
      Poland
      vw santana 82 1.6D vw santana trophy 87 vw quantum gl5 87 vw passat 84 coupe
      07-27-2012 12:44 PM #2
      So you wrote us "backspacing"?
      9J 5"
      8J 3"
      so ofset:
      9J positive 0,5" (12mm)
      8J negative - 1" (-25mm)
      ET:
      9J +12
      8J -25
      Assuming a correct calculation. I hope
      You can compare:
      9J et 15
      on front my friend have:
      http://imageshack.us/photo/my-images/195/1006403i.jpg/
      http://imageshack.us/photo/my-images/20/1006396e.jpg/
      here i have 8.5 et +33
      http://imageshack.us/photo/my-images/19/image1339.jpg/
      http://imageshack.us/photo/my-images/15/image1330.jpg/
      but to the fender edge is something like 3-4cm.
      So 8J with negative 25mm is crazy wide for Quantum
    3. Member sambocs's Avatar
      Dec 12th, 2010
      southern NH
      07-27-2012 01:01 PM #3
      wow. thank you haha didnt think i would get any answer that deep this helps alot!
      no i just have to read it 6 times to understand it and hopfully they will fit
      Quote Originally Posted by skopek View Post
      9J 5"
      8J 3"
      so ofset:
      ET:
      9J +12
      8J -25
      You can compare:
      9J et 15
    4. Member sambocs's Avatar
      Dec 12th, 2010
      southern NH
      07-27-2012 01:05 PM #4
      so if i can understand this the red one is 9j with et15? so 9j et15 would be similar to that fit ment and?
    5. Member sambocs's Avatar
      Dec 12th, 2010
      southern NH
      07-27-2012 01:13 PM #5
      now that i am looking at the pictures again it may be front spaceing
      if thats what you would call it
    6. Junior Member skopek's Avatar
      Jun 16th, 2007
      Poland
      07-27-2012 01:16 PM #6
      I hope my english isn't bad
      but for me your wheels aren't fit !
      8J will be 4 cm more outside than these!!! So thats SICK!
      But 9J will be only 3milimeters out than these
      True: the red one is 9j with et15
    7. Member sambocs's Avatar
      Dec 12th, 2010
      southern NH
      07-27-2012 01:20 PM #7
      im not worried if theyre flush or poke out just want to make sure that they dont hit the strut or anything and not hit anything to hard when it turns the front wheels
    8. Junior Member skopek's Avatar
      Jun 16th, 2007
      Poland
      07-27-2012 01:30 PM #8
      Depends on the size of the tire. Do you know what size you gonna use?
    9. Member sambocs's Avatar
      Dec 12th, 2010
      southern NH
      07-28-2012 02:13 PM #9
      195/65/14
    10. Member
      Aug 15th, 2007
      Virginia
      G60 on CIS-E and a bunch of other VW's
      08-22-2012 02:14 PM #10
      195/65-14 will fit provided the ET is at or near the factory which, IIRC, is ET35
      I am running 195/60-14's on my GTI, only issue is upper fender clearance, but at stock ET Teardrops I have no issues.
      a 65 is only slightly taller ~6mm OD so you should fit fine.
      G60 on CIS-E, Now Twin Screw on CIS-E
      http://forums.vwvortex.com/showthrea...-CIS-E-G-Lader
