Results 1 to 2 of 2
Thread: 09A EYN Overdrive Slipping Issues
  1. Member Terrible One's Avatar
    Apr 25th, 2002
    Portland, OR
    Dealer loaner
    07-27-2012 02:06 AM #1
    The car: 2002 Jetta GLS 1.8T Tip, 126,000 miles
    Searched for quite a while through the AT Forums... 1st through 4th and reverse function as normal, no issues. When in overdrive and over 20-25% load the trans-axle begins to slip pretty badly. Curious if anyone has had the same issues, looking for any insight before the trans-axle needs to be replaced. Any help is appreciated, thanks!
    Tyler
    Campagnolo 11spd. Volvo P2 V70R
  2. Member CoolAirVw's Avatar
    Mar 8th, 2007
    Kansas City Missouri
    85 Jetta TD sold 2001 Jetta Tdi, 2000 Jetta Tdi
    07-28-2012 12:12 PM #2
    If I'm understanding your description correctly I would assume you have a clutch burnt up (common).
    Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
    ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
    www.KansasCityTdi.com
