pictures can be seen here, ill upload them later
http://cgi.ebay.com/ebaymotors/Volks...b20d4d45#v4-43
#1
1990 Corrado VR6 Turbo Syncro
WVWDB4501LK025414
1995 OBD1 VR6 Motor
Racecraft Fabrication (NJ) Custom 6 point roll bar, fully welded
Megasquirt MS3/MS3X ECU
Kinetic T3/T4 Turbo Kit
Custom Syncro 2.5” downpipe
2.5” Stainless side exit exhaust with Flowmaster Hushpower muffler
ARP head studs
Mocal thermostatic oil cooler plate
Mishimoto oil cooler heat exchanger
Motor has all new plastic cooling parts
Motor has new timing chains
Air to Water Intercooler with giant front heat exchanger
500hp capable clutch
02C Transmission fully rebuilt with all brand new syncros and bearings
Transfer Case rebuilt with new bearings and seals
TDI (0.75) 5th gear
Peloquin differential in front transmission
New radiator
New Single 12” slim fan
New H&R monotube coilovers
Custom welded in Camber plates in front
All new wheel bearings
Custom heater core with defrost for windshield
15 Gallon Fuel Cell
Stainless firewall for fuel cell
Battery relocated to trunk in plastic battery box
Passat glass moonroof
Stock Corrado G60 blue dot front seats
European Corrado 3 point lap belts
European Corrado manual window regulators
16” Enkei wheels, freshly refinished in gray powdercoat
New 205/40-16 Falken Azenis tires
New Dual piston Audi Girling G60 front calipers
New MK4 aluminum rear calipers with stainless lines
New Hawk brake pads
New DriveShaftShop Stage Level 3 Axles (good for 500hp)
Car is tuned for 1 bar (15psi) of boost on 93 Octane gas and makes 350whp. Dyno proven and tuned by Rick Gifford of Bald Turbo Freak Racing.
The car runs and drives great. I recently drove it 10 hours round trip on vacation without issue. It gets 25mpg on the highway @ 80mph.
The paint is good on the car, it isn’t perfect, I would say it’s a 8 out of 10. The roll cage does have some chips in it as seen in the photos from driving the car. The car has about 15K on it since it was painted. It was previously ran with a G60 Syncro setup, the VR6 and all the above parts were installed this spring.
The windshield has a crack in it about 10" long. I have a good one that can be included in the sale.
I'm only selling because I have way too many cars, and need to thin the herd. The car is fast, and smooth.
Car will need to be picked up in Rochester, NY
I can help with shipping if necessary.
$12,000/BO
NO TRADES!!!
#2
#5
#10
dang I remember seeing this car being built on newcelica. Crazy!
http://autophiliac.wordpress.com/201.../so-it-begins/
Free bump either way
#13
the motor is down on compression on a couple cylinders
still runs and drives, just doesnt hold boost in the cylinders
$9K as is
#15
still for sale? if so link for more pics? by the way you do great work![]()
#18
