Results 1 to 9 of 9
Thread: Mk3 VR6 GTI Fans Not Coming On . Help Plz, Thanks
  1. Member Teh_Chris's Avatar
    Dec 30th, 2007
    Central VA
    04' MkIV TR .:R32 /04.5' MkIV BMP GLI/ 96' MkIII VR6 GTI
    07-27-2012 09:46 AM #1
    Ok so i took the car off the road to replace my exhaust and change my waterpump/crackpipe/thermostat/coolant hoses ....the cooling fans rans fine before & never gave me any issues the coolant temp gauge always stayed right at midpoint , now they wont turn on until the car gets to around 230 on the gauge ..... or not at all
    i now have the following BRAND NEW items and the fans still dont work ....
    -radiator
    -fans
    -71 degree tstat
    -sensor in the radiator
    -all 3 sensors in the tstat housing
    -fan control module
    -coolant ball and cap
    -coolant lines
    -crackpipe
    -waterpump
    can anyone thro any ideas in here that would help ive checked the all the fuses in the car , the only thing left it could be is the wiring . anyone know of any diagrams for hardwiring the fans to a toggle switch or even hardwiring them so they come on as soon as the car starts ??
    _R-1-3-5 _
    _└-┼-┼-┤_+AWD_=_WIN!!
    -__2-4-6____
  2. Member Capeman121's Avatar
    Aug 31st, 2011
    Nj
    95 vw golf
    08-10-2012 01:26 AM #2
    Quote Originally Posted by Teh_Chris View Post
    -radiator
    -fans
    -71 degree tstat
    -fan control module
    -coolant lines
    -crackpipe
    -waterpump
    Bump. Did u get any info or anyone got Ideas? Is wiring the fan power line to a fuse such as the radio or fuel pump a bad idea? Just a thought.
  3. Member silverjettin's Avatar
    Jan 15th, 2002
    nyc 10471
    1998 Ginster VR6
    08-10-2012 01:37 AM #3
    if everything worked good beforehand, id look at one of the new parts being faulty..possibly the thermostat?
    "Milk and cookies for the rookies, coffee and donuts for the grown-ups"
    "You'd be surprised what $3500 wheels can do to a $500 car"
  4. Member
    Jan 24th, 2011
    Rancho Cucamonga CA
    95 gti vr6
    08-10-2012 04:15 AM #4
    So fans dont work period? or only work on one speed?
    Car have AC or have you done any ac work....
    You need to test the wiring at the plug , at the Fan switch on the radiator. Check my past thread on my AC problems bud i have alot of videos i made on the varios areas to test. Pretty much your standard procedure for any fan problems.
  5. Member sk8too's Avatar
    Dec 22nd, 2004
    Offutt AFB, NE
    97 Jetta VR swapped. 2010 CC VR Executive
    08-10-2012 08:43 AM #5
    not being a jerk, but kinda sounds like maybe the thermostat may be in backwards...
    97 Jetta GL, OBDI VR swapped, 262 cams, GIAC chip, turn 2 style CAI, Magnaflow catback, 2.9 clone manifold, eurospec flywheel, B&G RS2 coilovers, MKIV front and rear seats
  6. Member silverjettin's Avatar
    Jan 15th, 2002
    nyc 10471
    1998 Ginster VR6
    08-10-2012 01:06 PM #6
    Quote Originally Posted by sk8too View Post
    thats what i was thinking
  7. Member Teh_Chris's Avatar
    Dec 30th, 2007
    Central VA
    08-13-2012 09:13 PM #7
    Quote Originally Posted by silverjettin View Post
    u ever tried to put a vr thermostat in ..... its literally impossible to do backwards the housing itself is very deep and the cover is just high enough for the tstat to clear .... the lip inside the housing will only allow it to go in one way .....
    _R-1-3-5 _
    -__2-4-6____
  8. Member Teh_Chris's Avatar
    Dec 30th, 2007
    Central VA
    08-13-2012 09:16 PM #8
    Quote Originally Posted by meximan View Post
    the ac was deleted and a shorter belt from MJM was used because the owner before me removed the ac lines. the fans only kicked in when the car hit around 230 degrees .... i said fvck the oem fans and wired in 2x10" electric slim fans to a switch and its been fine ever since holds solid just below midway on the temp gauge .
    _R-1-3-5 _
    -__2-4-6____
  9. Member Teh_Chris's Avatar
    Dec 30th, 2007
    Central VA
    08-13-2012 09:19 PM #9
    also had to make my own foglight harness cuz i got tired of d!cking around with the oem wire harness im just glad my engine harness works ... luckily im an electrician and can do this kinda shyt pretty easy , both wiring harness have been wrapped and heatshrinked up all nice and pretty
    _R-1-3-5 _
    -__2-4-6____
