VWVortex.com - 2001 vw jetta Wolfsburg 1.8t
    Results 1 to 11 of 11
    Thread: 2001 vw jetta Wolfsburg 1.8t
    1. n00b
      Jul 25th, 2012
      New york
      2001 jetta 1.8t Wolfsburg
      07-27-2012 10:37 AM #1
      Changed the oil in my jetta and after the
      Car started making a ticking noise from the valve cover it sounds like. Only does it When car is warm and idling at 800 rpm could it be wrong oil or something else please let me know I put 10w-30
      In there Mobil 1 synthetic oil any help would be great
      Aug 27th, 2011
      Markham/Etobicoke, Ontario
      2000 GTI 1.8t
      07-30-2012 12:36 PM #2
      1.8t recommends 5w-40 synthetic
      Try putting in the correct grade of oil
    3. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      01 Jetta Wolfsburg Ed, 04 Jetta GLI 24v 6spd
      08-25-2012 03:17 AM #3
      Quote Originally Posted by Ktt88 View Post
      I have the same car. I always run m1 10w-30 full synthetic, as do many of my friends. never had a problem, and my engine is still clean inside @ 180,000 miles. it's not the oil.
      My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
    4. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      80 Rabbit(DEAD), 94 Golf, '69 Type1 Sedan
      08-27-2012 12:28 PM #4
      Quote Originally Posted by Big_Tom View Post
      That is good for you, but if he changes the oil to the recommended grade, the noise should go away. I have seen this very same issue many times. The noise is the cam chain hitting the valve cover and the reason is that there is not enough oil pressure to keep the tensioner pumped up.
    5. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      08-27-2012 10:03 PM #5
      Quote Originally Posted by ps2375 View Post
      pure speculation is all that is
    6. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      08-27-2012 10:10 PM #6
      Really, cause you've changed oil in how many other 1.8T's? And you've had customers come to you and ask you what that sound is after they changed there own oil.
    7. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      08-29-2012 11:15 AM #7
      still pure speculation no matter how many oil changes you do
    8. 08-30-2012 08:25 PM #8
      It does sound like the cam adjuster. Like others have said it is more than likely a oil pressure issue or a bad adjuster.
    9. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      08-30-2012 10:26 PM #9
      Quote Originally Posted by 2482 View Post
      So it has been said.
    10. 08-31-2012 10:57 AM #10
      Its all speculation until the car is sitting in my bay , but all car questions on the internet pure speculation.
    11. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      09-03-2012 10:45 AM #11
      nice try lol
      this
