VWVortex.com - 2004 VW Jetta 2.0 - P0343 Camshaft Position Sensor help
    Results 1 to 10 of 10
    Thread: 2004 VW Jetta 2.0 - P0343 Camshaft Position Sensor help
    1. 07-27-2012 05:08 PM #1
      My check engine light came on while driving today, I didn't notice anything wrong until i looked down and saw it, then I drove home fine with no problem, but I'm scared to start it again. I checked the code and got P0343. Should i start by replacing the sensor and how? or do I need to replace the timing belt? (don't know when it was last replaced). I took pictures of the timing belt in case that helps.
    2. 07-27-2012 10:45 PM #2
      What's the mileage on your car/engine? The Bentley Service Manual indicates only a "check" of the Timing Belt at 80,000 miles.
    3. 07-28-2012 01:58 AM #3
      Quote Originally Posted by roadsterred View Post
      105,xxx miles
    4. 07-28-2012 09:28 AM #4
      have look at the thread on this page entitled
      "missing at 3000 RPM only after restarting car that is hot"
      I'm no expert on VW's, but maybe you have other symptoms that match what I just had.
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      07-28-2012 09:35 AM #5
      Verify that the engine is still in time and the belt has not jumped.
      Replace the cam sensor. You have to take the belt off to do it, might as well replace the belt, tensioner, and water pump at the same time. Regardless of what the Bentley says, I usually recommend timing belt replacements on these between 90-100k miles.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    6. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      07-28-2012 09:37 AM #6
      Quote Originally Posted by labuke View Post
      P0343 shouldn't be caused by a bad ECT sensor at all. Has that code gone away and not returned since the ECT replacement?
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    7. Member Cee-dub's Avatar
      Feb 19th, 2007
      Canadian Tundra
      02 Golf
      08-07-2012 02:54 AM #7
      At 86,000 mi., my '02 AZG threw P0343 and wouldn't rev past 3200 rpm. Replaced the cam position sensor, problem solved.
      There is a DIY here but in my opinion it's much easier to just remove the cam gear and finesse the new sensor in. (Leave the valve cover alone.) Do mind the tabs.
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      08-07-2012 10:28 AM #8
      Quote Originally Posted by Cee-dub View Post
      Definitely. Removing the whole cam to change the sensor is going WAY overboard and is totally unnecessary.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    9. 08-17-2012 12:55 PM #9
      Hey, I'm working on a 2004 Jetta 2.0L SOHC (BBW engine code), and I'm trying to figure out where the Cam sensor is located... dealer faxed me a picture, but it's just parts on a page, no diagrams as to what goes where. It's not like the one above, this one has a different looking cam gear on it.
    10. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      08-17-2012 01:33 PM #10
      Quote Originally Posted by chrisdavis97 View Post
      You should make your own thread
      BBW engine has variable valve timing and is totally different. The cam sensor is on the opposite end of the head from the gear.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
