Results 1 to 5 of 5
Thread: Charging problems... help
  1. 07-27-2012 09:23 PM #1
    Recently replaced my alternator and battery, but i am still having charging issues. the car will lose functions while driving, act like it is about to stall out, than come back from the dead like nothing happened. the last time it reset the clock and trip without completely stalling out.
    Any ideas? could it be some sort of relay for the alternator switching off and on? Im comfortable digging into my car mechanically and figuring things out, but i dont know much about relays and electrical issues and such. help!!
  2. Member orau22's Avatar
    Oct 15th, 2008
    NJ 08085
    SLAWbuilt MKIV & MKII Jetta Diesel
    07-27-2012 10:33 PM #2
    check your grounds maybe?
    are any of them loose, maybe clean them up and bolt them back down.
    SLAW [Straightline Autowerks]
    PM for fender rolling and coilover installs in South Jersey
  3. Junior Member
    Feb 12th, 2012
    Where the Navy sends me...
    '03 Jetta GLI, '93 Corrado SLC
    07-30-2012 02:04 AM #3
    Any associated codes? Sounds like it could be a faulty voltage regulator, but you would have codes showing voltage too high/low. And just as orau said, check your grounds. I'm sure you've seen them, but make sure the issue isn't the terminals on the battery. Damn gremlins....
    -Holmes
    People are always surprised that my car smells of crayons
  4. Junior Member
    Jan 17th, 2011
    Glendale,AZ
    2004 VW GTI VR6
    08-03-2012 12:06 AM #4
    Quote Originally Posted by accidentprone View Post
    Mine does this too i cant find the issue **** drives me nuts
    Sent from my DROID RAZR using Tapatalk 2
  5. 03-03-2013 07:51 PM #5
    back up... cars been sitting for ~6 months. any ideas? ground battery terminal looked fine... any advice on how to chase this problem around with a multimeter?
