Results 1 to 19 of 19
Thread: MK4 golf 2.0 battery to relay
  1. Member jolf43's Avatar
    May 10th, 2011
    East Cleveland
    Transgender Girl Car
    07-27-2012 11:17 PM #1
    Was wondering where you guys tap into the car through the firewall. its the last thing i need and im not finding help anywhere.
    my car is drive by cable too
    ill post my pics so far in a bit
    -Dan
    Instagram: dan_berhent
  2. Member jolf43's Avatar
    May 10th, 2011
    East Cleveland
    07-27-2012 11:20 PM #2
    the reason i need the power is so i can fill my rears with like 5 psi so they reach the nipple cause it scares me sitting like this
    Where i thought i could run the wite along with my drive by cable
    -Dan
  3. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    07-28-2012 04:12 AM #3
    Run it through the grommet behind the gas pedal. Please search just like other forums.
    @dan
    Hella4¯\_(ツ)_/¯ My Flickr
  4. Member jolf43's Avatar
    May 10th, 2011
    East Cleveland
    07-28-2012 08:38 AM #4
    Quote Originally Posted by Twilliams83 View Post
    @dan
    Theres no grommet behind my gas pedal
    -Dan
  5. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    07-28-2012 12:19 PM #5
    Quote Originally Posted by jolf43 View Post
    There is no grommet because your grommet is technically for your DBC system. Run the power wire through the main wiring harness that is located directly behind your "snorkel" that runs all the main ECU wiring down from your rain tray to behind you battery. There should be all the main power wires running through the firewall at that spot through a large grommet, unclip grommet ziptie, stretch grommet to allow for new power wire to go through also, then re-zip tie the grommet securely.
    Also for the rear's why don't you just use a nutsert like you are supposed to do to keep the upper mount in place??
  6. Member jolf43's Avatar
    May 10th, 2011
    East Cleveland
    07-28-2012 05:48 PM #6
    Nutserts cause the rears to pull apart at higher heights.everything is going well. Almost on the ground
    -Dan
  7. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    07-28-2012 10:46 PM #7
    Which rear bags are you using? What shocks are you using? Something here doesn't make sense...
  8. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    07-28-2012 11:39 PM #8
    never heard this in my life. ive been running nutserts for almost a year now and no problems at all.
  9. Member jolf43's Avatar
    May 10th, 2011
    East Cleveland
    07-28-2012 11:52 PM #9
    Quote Originally Posted by MechEngg View Post
    in my research, i found an airlift rep said that. i have air lift rears and slam xl fronts
    -Dan
  10. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    07-29-2012 06:34 AM #10
    i have the same set up, i just read in your other thread that you already blew a rear bag.
  11. Member jolf43's Avatar
    May 10th, 2011
    East Cleveland
    07-29-2012 11:21 AM #11
    I doubt i blew the bag. Ive yet to check, i think the line just loosened
    -Dan
  12. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    07-29-2012 12:17 PM #12
    Loosened? How would that happen
  13. Member jolf43's Avatar
    May 10th, 2011
    East Cleveland
    07-29-2012 12:23 PM #13
    Hit a pot hole last night. I doubt it could have blew the bag because its kind of holding air, i just have to bump it up while i was driving home
    -Dan
  14. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    07-29-2012 12:59 PM #14
    Dan, if you want help in the technical forums here you need to answer ALL questions that we ask, not just 1 or 2 of them. What rear shocks are you running? And as for the airlift rep stating that, if you could find the exact post and wording maybe there is a miscommunication between what you read and what was really implied due to certain situations that the original poster of the thread was facing.
    In my experience I have yet to have a bag bottom out before a shock...you would have to be using a shock that was longer than the OEM shocks for this to be possible
  15. Member jolf43's Avatar
    May 10th, 2011
    East Cleveland
    07-29-2012 02:15 PM #15
    Well i found out what happened. I disnt center the bag in the lower spring cup enough, so when i fell into the pothole, the lip of the cup pierced into the plastic bottom of my bags. As for my shocks, i have my rokkor shocks lol
    I decided to take a last effort chance at fixing the bag temporarily until i order some firestone rears
    -Dan
  16. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    07-29-2012 02:39 PM #16
    All of this.
    I love my airlifts
  17. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    07-29-2012 10:31 PM #17
    Thanks for answering the questions. I don't know where you read what you read but even with OEM shocks (long) the shock still bottoms out before the airlift bags do. I would HIGHLY recommend using a nutsert on the top to keep the bracket in place. As for the bottoms, that is unfortunate to hear, installation errors are quite common for people without lots of experience or mechanical knowledge. What i would recommend as the cheapest fix is to just get another rear bag. It would save on the cost of firestone bags and brackets and be the quickest solution
  18. Banned SoIAteAPancakeToday's Avatar
    Apr 21st, 2009
    mexico
    cheby
    07-30-2012 01:57 PM #18
    i have bilstein rear shocks which allow me to go higher than stock, i havent had any trouble with it pulling apart. i used to have raceland/rokker shocks and they top out way early, you wont have any problems using them and a nutsert
  19. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    South Burlington, VT
    335i
    08-03-2012 09:37 AM #19
    This dosn't look safe! Did you follow the instructions when you installed your setup or was it done by a professional? Where is your nutcert?
    - Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
