Results 1 to 12 of 12
Thread: Hey dubbers! A few questions..
  1. Semi-n00b TattoedDubist's Avatar
    Apr 17th, 2012
    Portland, Oregon, United States
    1986 Jetta GLI Wolfsburg
    07-28-2012 04:37 AM #1
    So I realize that many times young guys such as myself(19 years old) come onto the vortex and just spit out questions without ever having searched through the vast network that is the vortex. Personally, I try to avoid making myself look like an idiot, and so I have searched through the vortex in search of answers but I have yet to find the answers that I am looking for.
    To begin, I have owned two VW's the most recent and pertinent to my questions is a 1986 Jetta GLI Wolfsburg edition. Recently while cruising around downtown portland my clutch decided to randomly drop to the floor and not allow me to shift without performing a delicate clutch and throttle dance So I finally get her home and begin all the primary checks that I'm able to perform at my current location (i.e. pedal cluster, cable(manual adjust of course) and the position and movability of the arm). All checked out and so I decided my baby would have to wait until I could afford a tow to shop and just get it taken care of. Does anyone have any thoughts as to what the problem could be? I was thinking either slave cylinder or master cylinder?
    Secondly, being the poor bastard that I am I would like to keep the 8v until I am able to drop a 16 or 20v Turbo in there. Until then, I would like to continue to add power, and so I was considering a dam intake, new headers and a better exhaust. Any other ideas?
    Finally, I apologize if I missed any threads that answer these questions, but I appreciate any answers I may receive.
    Cheers Fellas!
  2. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    07-28-2012 09:57 AM #2
    If you have the auto adjusting cable, it is prolly time to replace the cable. You could do another auto adjusting cable (as this one prolly lasted a long time) or you could go with the older manual adjusting cable. You'll be able to tell the auto from the manual cables as the manual cable has a screw-in end at the tranny and the auto adjust cable has a larger diameter section on it that will compress when pushed on.
    FS:Sunroof Deflector
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    07-28-2012 01:49 PM #3
    No master/slave cylinder with a cable setup.
    So you said you verified the cable is still hooked up to the pedal and the clutch release arm on the transaxle? If that is the case, it sounds like the cable is toast (and perhaps the auto-adjusting version.
    I really suck at smog.
  4. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    07-28-2012 02:53 PM #4
    And before I forget, BUY A BENTLY MANUAL FOR YOUR CAR if you are planning on doing any work on it. That is the first and best tool to have.
  5. Semi-n00b TattoedDubist's Avatar
    Apr 17th, 2012
    07-28-2012 09:42 PM #5
    Quote Originally Posted by ps2375 View Post
    Quote Originally Posted by ziddey View Post
    First, thank you for the prompt replies, yet another reason I love being a VW owner. Community is everything!
    Second, I have the manually adjustable cable because I don't like the problems that are often associated with the auto adjusting cables.... I removed the cable to check it and couldn't find any problems with it, its in great condition... Also I have a Bently but it is lost in storage at the moment because I have been moving around so much I did some digging through the interweb and I am wondering if the problem could be that the pressure plate has been punctured? The manually adjusting cable was backed all the way out, so I'm wondering if the PO mis-adjusted it and the constant pressure on the pressure plate caused it to puncture.. I'm honestly at a loss at this point, so come monday I will be getting her towed to my local garage. I will keep you updated as to how this all ends up!
    Cheers Fellas
  6. Member
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    07-28-2012 09:52 PM #6
    I don't understand the situation. The clutch pedal is on the ground, even though the cable is fine and hooked up? That doesn't make sense.
  7. Semi-n00b TattoedDubist's Avatar
    Apr 17th, 2012
    07-28-2012 09:56 PM #7
    Exactly my point! thats why I'm assuming that there is something wrong inside the clutch
    The Jetta Makes The Girls Wetta
    [G]irls
    [L]ove
    [I]t
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    07-28-2012 10:01 PM #8
    I'm not sure if there's a spring at the pedal or in the transaxle for that car. Assuming it's in the clutch release fork, if the clutch pedal is on the ground, it means the cable is disconnected or snapped / frayed--stretched.
    Watch the clutch release arm while someone presses the clutch pedal.
  9. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    07-28-2012 11:43 PM #9
    AGAIN,
    As you don't seem to grasp how the clutch works on this car.
  10. Semi-n00b TattoedDubist's Avatar
    Apr 17th, 2012
    07-29-2012 01:17 AM #10
    AGAIN,
    The release arm still has movement when pressing on the pedal. I guess the cable could be stretched or frayed, but it did not appear to be when I removed it from the assembly.
    And honestly ps2375 I guess don't. Therefore I chose to ask people who do understand it and could assist me with the problem. If you read above posts you will see that I don't have access to my Bently Manual at the moment, so I'm doing the best with what I've got. I apologize if for some reason my lack of knowledge offends you, next time I'll make sure to ask questions about subjects that I am completely knowledgeable of, because that is after all how we learn correct?
    [G]irls
    [L]ove
    [I]t
  11. Junior Member
    Jun 30th, 2007
    chicago
    1979 4dr rabbit , 2010 JSW TDI
    07-31-2012 04:34 PM #11
    Check the actuation finger under the green cover on your tranny if it is good.
    It happend to my cabrio that the pushrod punctured the thrust plate in that case you need to drop the tranny.
    Both things will give you simmilar sympthoms that your car has
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    07-31-2012 07:29 PM #12
    how much movement does the arm have? can you easily move it the same with your hand? it may have a bit of play, especially if the cable is loose.
    if you can apply a lot of force and actually pull the arm up, you know it's fine.
    still sounds like the cable is bad.
