Our price list for items on this vehicle.
AIR FLOW METER 1.8L 85.00
ALTERNATOR 1.8L 85.00
AXLE LH FRONT 150.00
AXLE RH FRONT 150.00
AXLE LH REAR 85.00
AXLE RH REAR 85.00
AIR BAG LH DRIVER WHEEL 150.00
AIR BAG RH PASSENGER DASH 200.00
CALIPER LH FRONT !TT! 75.00
CALIPER RH FRONT !TT! 85.00
CALIPER LH REAR !TT! AWD 75.00
CALIPER RH REAR !TT! AWD 85.00
COMPUTER AIR BAG 8N8909601TA 135.00
COMPUTER COOLING FAN RELAY 50.00
COMPUTER HID CONTROL 100.00
COMPUTER THEFT LOCKING 8N8962267 125.00
COMPUTER TRANSFER CASE 02D900554 250.00
COMPRESSOR AC 1.8L 135.00
CONDESNOR AC 65.00
DOOR MIROR LH SILVER 115.00
DOOR MIRROR RH SILVER 115.00
DASH BOARD PANEL BLACK 225.00
DOOR WINDOW MOTOR RH 75.00
DOOR WINDOW MOTOR LH 85.00
ENGINE COMPUTER ECU 1.8L 180HP 200.00
ENGINE COOLING DUAL FAN 125.00
EXHAUST MANIFOLD 180HP 65.00
ENGINE !TESTED! RAN WELL ATC 1200.00
FRONT DOOR SHELL LH SILVER 250.00
FRONT DOOR SHELL RH SILVER 250.00
FRONT DOOR WINDOW COUPE LH 70.00
FRONT DOOR WINDOW COUPE RH 70.00
FENDER RH SILVER 125.00
FENDER LH SILVER 125.00
FLYWHEEL MT AWD 125.00
FUEL PUMP LH 100.00
FUEL PUMP RH 100.00
FRONT DOOR REGULATOR LH 125.00
FRONT DOOR REGULATOR RH 125.00
FRONT SEAT SET 200.00
FUEL TANK TT AWD QUATTRO 200.00
HEATER AC CONTROLS 125.00
HEAD LIGHT RH XENON VERY FOGGED 125.00
HEAD LIGHT LH XENON VERY FOGGED 125.00
HOOD SILVER EXT 350.00
INTAKE MANIFOLD ATC CODE 1.8T 50.00
IGNITION COLUMN WITH KEY MT 100.00
LOWER CONTROL ARM FRONT LH 135.00
LOWER CONTROL ARM FRONT RH 135.00
LOWER LOCATING ARMS REAR LH 100.00
LOWER LOCATING ARMS RH REAR 100.00
LH LOWER TRAILING ARM WITH HUB 125.00
RH LOWER TRAILING ARM WITH HUB 125.00
LID TRUNK HATCH WITH SPOILER SIL 350.00
MASTER CYLINDER BRAKE W/ESP 85.00
POWER BRAKE BOOSTER W/ESP 85.00
QUARTER PANEL LH,SILVER EXT,2DR 200.00
QUARTER PANEL RH,SILVER EXT,2DR 300.00
QUARTE WINDOW GLASS LH 60.00
QUARTER WINDOW GLASS RH 60.00
RADIATOR 1.8L,MANUAL 75.00
REAR BUMPER ASSEMBLY COUPE 350.00
RADIO AMPLIFIER 75.00
RADIO HEAD UNIT AM/FM/CASSETTE 75.00
RADIATOR SUPPORT 150.00
REAR SEAT 2DR,BLACK INT,LEATHER 250.00
SPEEDOMTER CLUSTER 135.00
STEERING PUMP 1.8L 75.00
SPINDLE HUB LH FRONT 150.00
SPINDLE HUB RH FRONT 150.00
STEERING RACK 175.00
STARTER 1.8L 75.00
STRUT FRONT LH 95.00
STRUT FRONT RH 95.00
THROTTLE BODY 1.8L 06A133062C 115.00
TAIL LIGHT LH 115.00
TAIL LIGHT RH 115.00
TRANSMISSION DXW CODE THIRD GEAR 600.00
TURBO CHARGER 1.8L 250.00
UNDER CARRIAGE SUB K FRAME 175.00
UPPER CONTROL ARM REAR LH 100.00
UPPER CONTROL ARM REAR RH 100.00
WHEEL SET COMPLETE SET OF FOUR 300.00
WIPER MOTOR FRONT WITH LINKAGE 95.00
WINDSHIELD COUPE 2DR 100.00
