Results 1 to 5 of 5
Thread: any turtle experts? need help keeping tank clean:(
  1. Member ridersna's Avatar
    Feb 22nd, 2010
    RI
    2derp
    07-28-2012 01:26 PM #1
    have had my baby res for about 3 months,just recently put him in a large 20 gallon that he loves
    hes bin fine in it up until a few days ago when it jsut randomly started to get very murky and dirty
    2/3rds filled long 20 gallon,whisper 20-30 gal filter small gravel on the bottom with larger rocks on top,and a use a weekly treatment of amonia and murk clear.
    also threw in a cleaner moss ball but nothing seem to work,started up outa no where and now i cant keep it clean...cleaned otu tank,filled it back up,day later its murky again!?!?!?!?
    i have a few feeder fish in but i doubt thats the problem as ive had fish in all the tanks
    HELP!!!!
    Because nothing quite says "classy" like a booty shot in the abortion clinic sink mirror.
  2. Member smi2710's Avatar
    Sep 6th, 2001
    on the east coast
    2006 325xi, 2001 KTM 400exc Supermotard, 2004 CRF/BBR 108cc
    07-28-2012 02:00 PM #2
    dont touch it for a month let everything do what it needs to do. By cleaning it you started the process all over. it will get murky and such but it will clear up and do not clean your filters as they are beneficial. Let everything go for a month , then do a 20% water change don't change the filter. Only change the filter if it is not running good. Everytime you try you do something to speed up the process you add week to the cycle process good luck
    well this is going to take some getting used too........
  3. 07-31-2012 05:05 PM #3
    Do you take them out to feed? Get a bucket or tub and if it's possible feed them outside of tank. Huge difference in take maintenance.
  4. Senior Member StormChaser's Avatar
    Jan 3rd, 2000
    Galesville, MD
    2006 Volvo V50, 1993 RX-7 R1, 1980 Hatteras 53MY, 2002 Grady White Release 283, 1958 Mohawk 14
    09-19-2012 03:19 PM #4
    Quote Originally Posted by smi2710 View Post
    Only change or CLEAN the filter if it is not running good.
    This is key. There is beneficial bacteria on it that helps clean the water. Clean the filter and it takes a while to build back up. Also don't foget to use chlorine remover when filling...the chlorine sterilizes the filter.
    Dave
    Demokratically Elekted Minister of Ginger Affairs and Fist Dates; Orakle of the Weathers; Creeper Extraordinaire of the Independent People's Republik of Offtopikstan
    Quote Originally Posted by Biz View Post
    If Chilledman and Stormy won't hit it, you know it's gone rancid.
    Aug 19th, 2012
    Atlanta
    2012 Turbo Beetle
    09-19-2012 04:35 PM #5
    Been in the aquarium business for about 8 years and doing maintenance for clients for about 5
    In my experience stop using all those chemicals except for a good dechlorinater add more doesn't equate to making it better
    Turtles are naturally "messy" animals and whispers are naturally "crappy" filters
    A canister or a marine land power filter would be to your benefit
    Only clean parts of the filter that are not a part of the biological process
    Things are floss and carbon should be replaced frequently
    If the cloudiness is from an ammonia bloom don't touch the filter and just kept at good water changes
