dont touch it for a month let everything do what it needs to do. By cleaning it you started the process all over. it will get murky and such but it will clear up and do not clean your filters as they are beneficial. Let everything go for a month , then do a 20% water change don't change the filter. Only change the filter if it is not running good. Everytime you try you do something to speed up the process you add week to the cycle process good luck
