Results 1 to 6 of 6
Thread: 08 r32 fwd only vcds codes
  1. Member ldaledub's Avatar
    Oct 14th, 2007
    2005 vw gli, 84 gti
    07-28-2012 03:09 PM #1
    had haldex and dsg service done on my 08 r. drive home noticed the car was only fwd. got home hooked up vcds and pulled these codes. my undertanding is that either the haldex fluid is not at the correct level or all of a sudden after the service my haldex controller took a dump?
    thanks pat
    Saturday,28,July,2012,17:40:20:20615
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Address 22: AWD Labels: 1K0-907-554.lbl
    Control Module Part Number: 1K0 907 554 L
    Component and/or Version: Haldex 4Motion 0116
    Software Coding: 0000001
    Work Shop Code: WSC 00000 000 00000
    VCID: 366986E9415C5C9
    2 Faults Found:
    01073 - Clutch Pressure System
    002 - Lower Limit Exceeded - Intermittent
    01155 - Clutch
    003 - Mechanical Failure - Intermittent
    CTS turbo,UNI,USP, Integrated eng.,Labonte motorsports,ESEtuning.
    Apr 12th, 2011
    IOWA
    Mk5 R32 #108, 08' Mk5 Jetta
    08-08-2012 03:27 PM #2
    have you checked the connectors?
    either way i would take it back to the servicing shop..
    Projekt German Auto Grüppe - German car entusiast club based in Iowa with members all over the Midwest
  3. Member ldaledub's Avatar
    Oct 14th, 2007
    2005 vw gli, 84 gti
    08-08-2012 04:00 PM #3
    Sorry didn't update here. Took it back to the shop the Haldex fluid level was low. So they redid the service and checked fluid after test drive like they were supposed to do the first time and topped it off now all is well. Thanks though
  4. Member Ikey3125's Avatar
    Jan 27th, 2008
    Fairchild AFB/Spokane WA
    08 .:R 2763/5000
    08-10-2012 01:19 AM #4
    Quote Originally Posted by ldaledub View Post
    have a feeling this is what is up with mine too...anyone know if its bad if you've run the car for a while with low fluid?
  5. Member ldaledub's Avatar
    Oct 14th, 2007
    2005 vw gli, 84 gti
    08-10-2012 05:24 AM #5
    Apparently the rear diff goes into safe mode so pretty much it just free wheels. So none
  6. Member Ikey3125's Avatar
    Jan 27th, 2008
    08 .:R 2763/5000
    08-10-2012 12:34 PM #6
    Good to know, probably will to a Haldex service sometime this upcoming week, gotta do an oil change anyways, so might as well do both at the same time.
