Results 1 to 5 of 5
Thread: i need help/advice on installing the passenger axle flange.
  1. Member MÄDDNESSS's Avatar
    Oct 18th, 2010
    mi casa
    '03 GTI 1.8FT, '88 Jetta Coupe.
    07-29-2012 05:01 AM #1
    so as some of you may know im in the middle of a 6 speed swap into my mk4 GTI 1.8T.
    conversation thread here.
    http://forums.vwvortex.com/showthrea...ap-help-advice.
    so i got a round to installing the 02m (tranny code ERR) today. i needed to take off the passenger axle flange to mount it up.
    but now i cant figure out how to get the damn thing back on.
    any help would be appreciated.
    i did search and all i found was, "compress the axle flange enough to get the bolt in" but it doesnt specify on how to do it. im gonna try using a big c clamp tomorrow.
    Just another SoCal build/progress thread (under construction)
    Look what I brought home today! (sitting in SoCal)
    Quote Originally Posted by carlhuebner View Post
    bitch doesn't get sensored, n00b.
    Quote Originally Posted by 87vr6 View Post
    Stop. Sell your VW, get off vortex.
    Nov 19th, 2008
    Atlanta-Chicago
    92 verde rado gernade(dd),90Q 20v, red rado 16vt(in progress)
    07-29-2012 09:51 PM #2
    I would put the pass drive axle flange last when it's in the car. 2 reason, it make it easier to install transmission without flange in, it clears the flywheel assembly. Once the transmission in, use pry bar a press against by wedging the pry bar on back engine, that will compress the flange spring to put the Allen bolt in.
  3. Member MÄDDNESSS's Avatar
    Oct 18th, 2010
    mi casa
    07-30-2012 03:14 AM #3
    why does everybody say it wont clear the clutch?
    when i tried to mount the tranny with the flange, it DID clear the clutch. what it wasnt clearing was the sleeve that stuck out of the block. the sleeve goes into the bell housing, and a bolt goes through the block and sleeve and threads into the tranny. its the only bolt that goes from the block to the tranny.
    its on the back side of the block.
    i'll snap a pic and post it for clarification.
    and i didnt think about using a pry bar to compress it. thanks.
    why is it spring loaded anyway? i mean, its bolted in. so what purpose does the spring provide?
  4. Member
    Nov 19th, 2008
    Atlanta-Chicago
    08-01-2012 09:24 PM #4
    Most all transmission flanges are spring loaded, either using c-clip or bolted, it need extra tension for diff. Yes you can leave inner flange on, just have to rotate the transmission up more to clear flywheel and subframe. It just easier to remove the flange to have more clearance if DIY thing.
  5. Member MÄDDNESSS's Avatar
    Oct 18th, 2010
    mi casa
    08-01-2012 11:09 PM #5
    Quote Originally Posted by MÄDDNESSS View Post
    Quote Originally Posted by chc-rado View Post
