I would put the pass drive axle flange last when it's in the car. 2 reason, it make it easier to install transmission without flange in, it clears the flywheel assembly. Once the transmission in, use pry bar a press against by wedging the pry bar on back engine, that will compress the flange spring to put the Allen bolt in.
