Results 1 to 13 of 13
Thread: VCDS Faults after Upgrading CANBUS
  1. Junior Member DecepticonR32's Avatar
    Jun 10th, 2012
    Kennesaw, GA
    '08 VW R32
    07-29-2012 11:33 AM #1
    I installed an RCD-510, and MDI box, but I needed a new canbus, so that the MDI box would work. I upgraded the Canbus to a revision L and had these issues.
    Prior Scan with Old Canbus:
    Sunday,29,July,2012,09:11:06:11083
    VCDS Version: Release 11.11.3 (x64)
    Data version: 20120401
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 47 52 55 56 65
    VIN: Mileage: 79090km/49144miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    65-Tire Pressure -- Status: OK 0000
    Address 01: Engine Labels: 022-906-032-BDB.lbl
    Part No SW: 022 906 032 KR HW: 022 906 032 GP
    Component: R32-DQ-LEV2 G 1098
    Revision: 1QH02--- Serial number: VWX7Z0G63ND83K
    Coding: 0000178
    Shop #: WSC 01279 785 00200
    VCID: 65EF6E26AC7AE71
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 011 CC HW: 02E 927 770 AD
    Component: GSG DSG 082 1405
    Revision: 05108020 Serial number: 00001008191164
    Coding: 0000020
    Shop #: WSC 04940 001 00001
    VCID: 5285A5FACDF4609
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
    Component: ESP 4MOTION MK60 0102
    Revision: 00H13001
    Coding: 0021128
    VCID: 72C5057A6DB4009
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
    Component: ClimatronicPQ35 120 1111
    Revision: 00120021 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 79D7325630C2731
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 01000007379353
    Coding: E68F8F214004150047140000001400000009730B5C00010000 0000000000
    Shop #: WSC 05226 444 54660
    VCID: 71C70A7668B23B1
    Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 160707 021 0501
    Coding: 00038805
    Shop #: WSC 05226
    Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
    Component: RLS 200707 046 0204
    Coding: 00479269
    Shop #: WSC 05226
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
    Component: 6T AIRBAG VW8R 034 8000
    Revision: 05034000 Serial number: 003B6D09580C
    Coding: 0013908
    Shop #: WSC 01269 785 00200
    VCID: 6CF91B024F90D69
    Part No: 1K0 959 339 G
    Component: BF-Gewichtsens. 007 0007
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
    Component: J0527 036 0070
    Coding: 0012122
    Shop #: WSC 07235 444 84792
    VCID: 8127DAB6D812AB1
    Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K6 920 974 D HW: 1K6 920 974 D
    Component: KOMBIINSTRUMENT VDD 1216
    Revision: V0002000 Serial number: VWX7Z0G63ND83K
    Coding: 0007203
    Shop #: WSC 01367 785 00200
    VCID: 354FFE665C5A571
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H04 0021
    Revision: H04 02 Serial number: 110707F2001429
    Coding: FF8F034207000000
    VCID: 2F43CC0EBE066D1
    1 Fault Found:
    00469 - Infotainment Databus in Single Wire Operation
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 169
    Reset counter: 81
    Mileage: 79001 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:12:06
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 L
    Component: Haldex 4Motion 0116
    Coding: 0000001
    VCID: 364DF96A415C5C9
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 1216
    Shop #: WSC 07235 444 102999
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
    Component: Tuer-SG 006 120A
    Coding: 0001077
    VCID: 3851F7524B48AA9
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 M
    Component: EPS_ZFLS Kl.141 H08 1901
    Shop #: WSC 00000 028 00001
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
    Component: KSG PQ35 RDK 052 0221
    Revision: 00052000 Serial number: 00000000000000
    Coding: 139006885103483F2902058FB0080A04889C00
    VCID: 8429D3A2C700BE9
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 47: Sound System Labels: 3C0-035-456.lbl
    Part No: 1K6 035 456 A
    Component: 08K Audioverst. 0005
    Revision: 00003000 Serial number: 00000000141777
    VCID: 2A75DD1A85E4089
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
    Coding: 0001076
    VCID: 3957F2567042B31
    Address 55: Xenon Range Labels: 1T0-907-357.lbl
    Part No: 1T0 907 357
    Component: Dynamische LWR 0003
    Coding: 0000004
    VCID: F4C9836297A08E9
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
    Component: Radio Prem-8 H10 0035
    Revision: -----20S Serial number: VWZ4Z7J3030445
    Coding: 0500040001
    Shop #: WSC 00066 123 12345
    VCID: 61E77A3678528B1
    4 Faults Found:
    00870 - Bass Speaker Front Left (R21)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 53
    Reset counter: 81
    Mileage: 78198 km
    Time Indication: 0
    Date: 2000.15.00
    Time: 19:07:43
    00871 - Bass Speaker Front Right (R23)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 53
    Reset counter: 81
    Mileage: 78198 km
    Time Indication: 0
    Date: 2000.15.00
    Time: 19:07:43
    00872 - Bass Speaker Rear Left (R15)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 53
    Reset counter: 81
    Mileage: 78198 km
    Time Indication: 0
    Date: 2000.15.00
    Time: 19:07:43
    00873 - Bass Speaker Rear Right (R17)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 53
    Reset counter: 81
    Mileage: 78198 km
    Time Indication: 0
    Date: 2000.15.00
    Time: 19:07:43
    Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
    Component: RDK 0450
    Coding: 0100101
    End ---------------------------------------------------------------------
    New Canbus Installed:
    Sunday,29,July,2012,11:29:56:11083
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 42 44 46 47 52 55 56 65
    04-Steering Angle -- Status: OK 0000
    2E-Media Player 3 -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    Coding: 0000178
    Coding: 0000020
    Revision: 00H13001
    Coding: 0021128
    Coding: 00038805
    Shop #: WSC 05226
    Coding: 00479269
    Shop #: WSC 05226
    Coding: 0013908
    Coding: 0012122
    Coding: 0007203
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533 Gateway H07 0052
    Revision: H07 01 Serial number: 150408F2002168
    Coding: ED831F071002120002
    VCID: 3041CF72A338729
    1 Fault Found:
    01305 - Databus for Infotainment
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 1
    Fault Frequency: 11
    Mileage: 79096 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:27:20
    Coding: 0000001
    Address 2E: Media Player 3
    Cannot be reached
    Coding: 0001077
    1 Fault Found:
    00105 - Signal Central Locking SAVE/LOCK Drivers Side
    008 - Implausible Signal - Intermittent
    Cannot be reached
    Coding: 0001076
    Coding: 0000004
    Address 56: Radio
    Cannot be reached
    Component: RDK 0450
    Coding: 0100101
    How can I reach the unreachable modules like Sound System, Radio, Media Player
  2. 07-29-2012 08:15 PM #2
    Maybe your CAN is crossed at H/L?
    Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
    7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
    European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
    Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
    vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
  3. Junior Member DecepticonR32's Avatar
    Jun 10th, 2012
    Kennesaw, GA
    '08 VW R32
    07-29-2012 08:16 PM #3
    Quote Originally Posted by Jack@European Parts View Post
    Where should I be looking to verify correct wiring, or possible errors in wiring?
    I would assume under the dash, driver side, near the canbus and also towards the radio.
  4. 07-29-2012 10:06 PM #4
    Reference the wiring diagram in the repair manual for each respective application to verify.
  5. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    '10 Skoda Octavia vRS Combi / '67 Ford Mustang Conv.
    07-30-2012 10:22 AM #5
    You can also verify that the new/used gateway isn't faulty by plugging the old one back in for a test, wouldn't be the first one that fails...
  6. Junior Member DecepticonR32's Avatar
    Jun 10th, 2012
    Kennesaw, GA
    '08 VW R32
    07-30-2012 03:29 PM #6
    After putting back in the old canbus:
    Monday,30,July,2012,14:59:07:11083
    Dempsey Garage
    Chassis Type: 1K0
    VIN: WVWKC71K18W066848 Mileage: 79270km/49256miles
    15-Airbags -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    Coding: 0000178
    Coding: 0000020
    Revision: 00H13001
    Coding: 0021128
    Coding: 00038805
    Shop #: WSC 05226
    Coding: 00479269
    Shop #: WSC 05226
    Coding: 0013908
    1 Fault Found:
    01217 - Side Airbag Igniter; Driver Side (N199)
    007 - Short to Ground - MIL ON
    Coding: 0012122
    Coding: 0007203
    Coding: 0000001
    Coding: 0001077
    1 Fault Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 121
    Time Indication: 0
    Coding: 0001076
    Coding: 0000004
    Coding: 0500040001
    4 Faults Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 81
    Mileage: 79279 km
    Time Indication: 0
    Date: 2000.15.00
    Time: 14:50:39
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 81
    Mileage: 79279 km
    Time Indication: 0
    Date: 2000.15.00
    Time: 14:50:39
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 81
    Mileage: 79279 km
    Time Indication: 0
    Date: 2000.15.00
    Time: 14:50:39
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 81
    Mileage: 79279 km
    Time Indication: 0
    Date: 2000.15.00
    Time: 14:50:39
    Component: RDK 0450
    Coding: 0100101
    I was able to clear the code for Address 46: Central Conv. So ignore that in my post.
    But now I have an airbag light on.
    I am assuming the canbus I purchased was faulty, so I am returning that to eBay and finding another one.
  7. Junior Member DecepticonR32's Avatar
    Jun 10th, 2012
    Kennesaw, GA
    '08 VW R32
    08-02-2012 08:21 PM #7
    Airbag light fixed at dealer, they replaced the side igniter.
    Got a replacement canbus in the mail today, I'll swap it this weekend, and see how things go.
  8. Junior Member DecepticonR32's Avatar
    Jun 10th, 2012
    Kennesaw, GA
    '08 VW R32
    08-03-2012 06:21 PM #8
    Must have been a bad canbus. iPod now works!!!!
    Here's what faults I have left:
    Revision: H07 01 Serial number: 111007F1000891
    Coding: ED831F071002120000
    1 Fault Found:
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 188
    Mileage: 79479 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:10:36
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
    Component: SG EXT.PLAYER H13 0090
    Revision: A1001003 Serial number: 7667763706
    Coding: 010000
    VCID: 266D292A51FC2C9
    2 Faults Found:
    00457 - Control Module for Network (J519)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 254
    Reset counter: 228
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 6
    Reset counter: 100
    Time Indication: 0
    Coding: 0500040001
    4 Faults Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 188
    Mileage: 79479 km
    Time Indication: 0
    Date: 2000.15.00
    Time: 00:11:30
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 188
    Mileage: 79479 km
    Time Indication: 0
    Date: 2000.15.00
    Time: 00:11:30
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 188
    Mileage: 79479 km
    Time Indication: 0
    Date: 2000.15.00
    Time: 00:11:30
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 188
    Mileage: 79479 km
    Time Indication: 0
    Date: 2000.15.00
    Time: 00:11:30
    Not sure about these codes, but everything seems to be functioning correctly except for the aux input. I have the kufatec wiring harness, so the pins should be set correctly, but honestly, i'm not too worried about the aux working.
  9. Junior Member DecepticonR32's Avatar
    Jun 10th, 2012
    Kennesaw, GA
    '08 VW R32
    08-06-2012 04:38 PM #9
    I'm still getting the 00469 - Infotainment Databus in Single Wire Operation
    012- Electrical Fault in circuit
    I'm assuming its the Kufatec wiring harness now. This is causing the radio to randomly lose power and then come back up. Sometimes it's 10 times in a trip, other times it's like 2-3 times. It varies.
    Also, the Audio function on the MFD occasionally is not available.
    I just got home and did a scan, the radio is playing (it turned off and on about 2 times driving home) But the audio function isn't on the MFD. The scan showed the same single wire fault, and couldn't talk to the radio and media controllers though.
  10. Junior Member DecepticonR32's Avatar
    Jun 10th, 2012
    Kennesaw, GA
    '08 VW R32
    08-14-2012 11:08 PM #10
    VW replaced the RCD-510 under warranty It was deemed defective. Coding for steering wheel buttons reset. Everything works! Case closed.
  11. Member
    Apr 11th, 2009
    Norcal - Bay Area
    09 TR GTI, 99 18J Miata
    08-14-2012 11:30 PM #11
    Quote Originally Posted by DecepticonR32 View Post
    So it was a bad RCD510 and a bad CAN module? How unlucky!
    Will VAGCOM for beer, NorCal 94043
  12. Junior Member DecepticonR32's Avatar
    Jun 10th, 2012
    Kennesaw, GA
    '08 VW R32
    08-14-2012 11:33 PM #12
    Quote Originally Posted by scenturion View Post
    Yup. what an odd turn of events! I hope my next project (running the 4th wire for LED tail lamps, adding in a trigger wire for the rear fog, and coding all of it) turns out a bit better.
  13. Member
    Apr 11th, 2009
    Norcal - Bay Area
    08-15-2012 01:19 AM #13
    My fog trigger wire rattles like crazy. Take the time to route it properly behind the dash or you'll regret it.
