Results 1 to 15 of 15
Thread: mk3 8v problems
  1. 07-29-2012 04:08 PM #1
    When running and ac and everythings on and its real hot out side.At a stop light the car will die but start right back up.I think its some sort of vacuum problem did tune up vacuum lines,water pump,fuel filter.Trying to help a friend out in North Carolina fix his car don't know much about 8v mk3 any help will do thanks.
  2. Member jiffyjetta's Avatar
    Mar 13th, 2010
    Beaverton, Or
    Scirocco 16v, A6 Bi-turbo, 89 GLI
    07-29-2012 04:22 PM #2
    Scan it for codes and post your results.
    It is nearly impossible to diagnose a vehicle without seeing it or without codes.
    -ASE Certified-
    -FS:87 Scirocco 16V
    Quote Originally Posted by brobs is back View Post
    I'm going to hook up the cables for my vr shifterbox to each of my nuts. Then I'll just cough to shift
  3. 07-29-2012 05:41 PM #3
    yeah thats what i told my friend i thought night be some vacuum lines some where,but he says just shuts off.He's to far away to go there so will try and help him.Anymore thoughts on the subject please let me know.
  4. Member Thecleaner's Avatar
    Jul 15th, 2002
    The Couve
    LE6Z, LE6B, L90E, LN5Y, L90E
    07-30-2012 01:00 AM #4
    Transfer pump.....
  5. Member Sticky Tape's Avatar
    Mar 29th, 2009
    seattlish
    HPA R32, GTD
    07-30-2012 02:07 AM #5
    Quote Originally Posted by Thecleaner View Post
    Transfer pump.....
    Not on a MKIII.
    www.demonrally.com
    www.finetuningperformance.com
    for technical help, post here. http://forums.pnwfahren.com/ I dont offer much help on Vortex anymore
  6. Member cabriosnap's Avatar
    Apr 24th, 2009
    Oregon City, OR
    98 Cabrio, 1983 302 RX-7, 1978 F250,02 Beetle TDI, 86 Ranger 4x4,83 16Vaba-T cabriolet project
    08-04-2012 12:11 PM #6
    do you have any battery/alternator issues or charging issues of any kind? sounds like the extra drag caused from your a/c compressor kicking on may be putting strain on yourt alternator....just a theory
    -VDUBN-
    Team Creampie
    My Car looks Dumped cuz theres Hookers in the Trunk
    Quote Originally Posted by 942drvento
    Instead of the Beer Avatar they need a Blunt
    Quote Originally Posted by uzi did it View Post
    4 doors more whores!
  7. Member Keltz's Avatar
    Feb 23rd, 2010
    SW Portland
    '98 Jetta GL 2.0 8v
    08-04-2012 03:01 PM #7
    Check your IAC valve. That was the issue was for mine
    Quote Originally Posted by adam the caveman
    volkswagens are like children: you have an unconditional love for them, sometimes you want to slap them retarded, and they're costing you money from the day you get them.
  8. Member jiffyjetta's Avatar
    Mar 13th, 2010
    Beaverton, Or
    08-05-2012 10:12 AM #8
    I think you should aimlessly throw parts at it.
    Then when it is not fixed, scan it for codes.
    -ASE Certified-
    -FS:87 Scirocco 16V
  9. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    84 scirocco,83 Scirocco(parts),76 scirocco"Sabine",85 ledgends turbo scirocco
    08-06-2012 05:45 AM #9
    Quote Originally Posted by jiffyjetta View Post
    i think you should aimlessly throw parts at it.
    jack ass.
  10. Member jiffyjetta's Avatar
    Mar 13th, 2010
    Beaverton, Or
    08-06-2012 01:51 PM #10
    Quote Originally Posted by 83mk2scirocco View Post
    jack ass.
    He needs to scan the vehicle for codes OR have someone diagnose it in person.
    It is just a big guessing game right now, at least 3 different suggestions.
    -ASE Certified-
    -FS:87 Scirocco 16V
  11. Banned
    Apr 29th, 2012
    NW
    Lot's of Nike's
    08-06-2012 01:56 PM #11
    jack ass.
    really?
  12. Member bluidgti's Avatar
    Apr 4th, 2006
    Everett / Tacoma
    Mk1 Jetta coupe TD, MK3 2.0 GTI SC, MK6 Golf TDI, 2004.5 GLI (GF's)
    08-07-2012 12:10 AM #12
    if its obd2 then there is a signal wire that tells the ECU that the A/C is on so it can bump open the throttle a bit. if its obd1 then there is an IAC valve that does the same thing as the throttle. Id get my bentley out and tell you exactly what wire it is but its not handy. Does your AC work when your car is off idle? like higher than 1000 rpm? also post what year your car is.
  13. Member bluidgti's Avatar
    Apr 4th, 2006
    Everett / Tacoma
    08-07-2012 12:14 AM #13
    I disagree completely. Mk3s are NOT so sophisticated that you cant fix them without a code reader. If the CEL is on then yeah, obviously find out why. This issue has a high probability of not causing a CEL though.
  14. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    '67 rolls royce, '67 mgb gt, and a '13 tdi
    08-07-2012 11:36 AM #14
    i think the problem is the lack of a turbo, and its missing 8 valves.
    might try that?
  15. Member 75rusty's Avatar
    Aug 6th, 2003
    Washington
    S8, GTI
    08-08-2012 02:07 PM #15
    Quote Originally Posted by ValveCoverGasket View Post
    might try that?
