Results 1 to 17 of 17
Thread: 1981 Scirocco S 2.0 16V Northern Minnesota $3300
  1. 07-29-2012 04:26 PM #1
    We're moving to Alaska, and the Sciroccos must go.
    2.0 16V approximately 95,000 miles
    Regular FF transmission with 90mm half-shafts.
    Techtonics short shift kit
    16V Scirocco exhaust manifold, Techtonics cat and down-pipe
    2.25" Techtonics exhaust with SuperSprint group N muffler
    280mm (11") front brakes with Zimmerman cross drilled rotors
    Audi 5000 turbo calipers with Ferodo pads
    DOT stainless steel lines
    92 GLI 16V rear brakes
    16V brake servo and master cylinder
    Polyurethane bushings
    Neuspeed sway bars (22/28)
    Neuspeed lower stress bar
    Bilstein Sport spings
    Bonrath spring perches
    OE strut bearings
    poly rear upper strut bearings
    16x7 BBS RX wheels on Yokohama 205/40ZR16 A520 tires
    92 GLI front seats
    Oil pressure, clock, voltmeter, oil temperature (not functioning)
    Leather shift boot
    Momo Race Air leather knob
    Leather hand brake boot
    billet hand brake lever
    New carpet
    H1/H4 lights fully relayed.
    I've owned this car for 10 years, and it has been very reliable. The ride is really rough for the roads around here, but the handling makes up for it.
    Paint is original. A lot of dings and dents throughout, but aside from a small rust spot on the rear hatch (see photo), it is a rust free car. One body issue is that the right rear was dented slightly (a couple of mm?) which results in water getting into the wheel well behind the rear tire. I sponge it out every time I was the car and don't drive it in the rain, but it should be attended to if you are not into doing that.
    Dash is cracked, but I have a good one that I will be selling (parts list coming).
    The engine does not put out as much power as I would expect it to. I would estimate that it is only making about 105 HP. It could be simple (or not), but I've never put the time into tracking it down. I bought the car like this and have not had it get better or worse.
    Side window rubber and wipers are weathered.
    Asking $3300. Must sell by the end of August.
    This is where the car was dented, causing a water leak through the taillight to body gasket.
    The only rust spot that I can find on the car:
    Paint is weathered and checked:
    More images of the dents and dings
    Aug 12th, 2011
    Rust belt , Pennsyltucky
    Hemi Jeep , GMT400 Suburban , '87 Scirocco 16v(sold),'07 Rabbit(sold)
    07-30-2012 11:23 AM #2
    The "I want this car but too far to drive " bump
    Very nice classic VW.
    Alaska.
    Wow.
    Northern Minn. not cold enough???
    Thredkilla supreme
  3. 07-30-2012 09:17 PM #3
    Interested.
    PM me.
  4. 07-31-2012 06:56 AM #4
    PM'd
  5. Member der hauptmann's Avatar
    Jul 17th, 2006
    Mondovi, WI
    87 Scirocco 16V, 88 Jetta GLI 16V, 91 Cabriolet, 03 Audi A4 Avant
    08-02-2012 04:26 PM #5
    Did you do the 16v swap? Any info on that? Interested.
  6. 08-02-2012 10:55 PM #6
    Quote Originally Posted by der hauptmann View Post
    Not on this car. I purchased with the swap. I've done one, and this swap is decent (I would rate it 8.5/10; my swap was a 10/10 of course) The engine is a 9A 16V with California emissions, It does not have A/C or power steering. It starts well, and runs well, but I would expect it to run well under 7 seconds to 60 mph. I clock something in the mid 8 second range.
    Mar 10th, 2004
    Machias Maine
    81 Scirocco S 84 Jetta 83 Rabbit Pickup
    08-14-2012 01:59 PM #7
    Tool nice of a car not to bump! Needs a good home!
  8. Member scirocgvnr's Avatar
    Apr 10th, 2004
    Atascadero,CA
    83 Rabbit GTi (show), 79 Scirocco, 85 Jetta Turbo Diesel
    08-15-2012 10:46 PM #8
    I built this car and he is selling it way too cheap!
    Wow! 10 years of hoarding parts for it too
    Motronic... hand fabbed air box.. bilstein Sports..... factory roof
    my old GPR project car
    80's I'm living in the 80's (Killing Joke)
  9. Member techfx's Avatar
    Oct 16th, 2008
    Pittsburgh, PA
    1988 VW Scirocco 16v Tornado Red (RIP), 09 Subaru Outback 2.5, 02 Golf TDI
    08-16-2012 09:30 AM #9
    I'm more MKII fan, this is a nice MKI that definitely catches my eye. Need more cash myself, hope it finds a good home.
  10. 08-16-2012 08:46 PM #10
    I know I'm selling it way too cheap. If I had three months to sell it rather than three weeks, I'd be asking for more.
  11. 08-17-2012 12:19 AM #11
    Any chance you're driving through Alberta on your way to Alaska?
  12. Member kerensky's Avatar
    Mar 5th, 2001
    Norman, OK
    '89 Fox GLS, '89 Fox wagon, '73 914, '72 'vert.
    08-24-2012 12:09 AM #12
    Smokin' deal - if only I had half the money I'd be on this like white on rice. You're only a week out, man. What happens if no one steps up? You have anyone semi-local you can leave it with and take your time selling?
  13. 08-25-2012 09:43 AM #13
    The car and all the sheet metal in my post for parts (6 doors, 3 hatches, 2 hoods, one of the windshields) are now all in Detroit residing in the garage of a relative. 900 miles closer to civilization and much easier to shipping logistics.
  14. Member kerensky's Avatar
    Mar 5th, 2001
    Norman, OK
    08-25-2012 05:41 PM #14
    That's good news, I was afraid that you were going to have to do something rash.
  15. 08-29-2012 08:02 AM #15
    You probably in Alaska by now but I would like to talk on the phone regarding this car and parts.
    PM sent
  16. 08-30-2012 08:58 AM #16
    Quote Originally Posted by tlaaartz View Post
    PM sent
    PM replied. I head out later today.
  17. Member ohiodub_99.5's Avatar
    Jun 4th, 2007
    Cincy.
    jetta coupe...
    08-31-2012 08:04 PM #17
    pm sent... extremely interested... And $ in
    | 864 Syndicate | blitzkraft | drivewaybuilds |
    ...not so static meow am i...
