Results 1 to 3 of 3
Thread: Mkiv GLI 6speed Clutch sinks
    Apr 23rd, 2010
    Orlando
    2005 PG VW GLI
    07-29-2012 09:35 PM #1
    So my clutch just sank. I've never had an issue with it grabbing, slipping, anything. I got in my car just now and it sank. It engages and I can turn the car on but the clutch doesn't come back...I am leaking oil so I am guessing it is the master cylinder or something. Any input can help.
  2. Member DUBZAK's Avatar
    Oct 26th, 2009
    Doin' W3rk at the Shop or my House
    Corrado SLC, Audi A8 QUATTRO
    07-29-2012 10:39 PM #2
    Slave cylinder. You have to pull the trans anyway, time to do the clutch.
    |Corrado SLC 2.9LVR6|Corrado Keyless Entry | A8 "Grape Ape" | SPOONFEDTUNING |FOURSEASONTUNING|DUBNUTZ|
    Quote Originally Posted by pileofredparts View Post
    Do you guys remember the time that Ryan kid started mixing and matching rods and end caps and then his motor wouldnt turn over? I do
  3. 07-30-2012 05:36 PM #3
    where is it leaking? if its from the gap where engine meets tranny then transmission needs to come off. If its where the bleeder valve is then some o-rings are bad.
