Results 1 to 4 of 4
Thread: Headlight Adjustment
  1. 07-29-2012 11:45 PM #1
    I did some searching here and through Google, but I cannot find the original page I found earlier (I forgot to bookmark it )
    Essentially, I understand that there are plastic allen screws (well the heads are plastic) on top of the headlight which you can use to manually adjust the headlights up,down, as well as side to side. However, when I do this (with the car off), the car automatically readjusts the headlights back to their previous position. Unfortunately, for whatever reason, my headlight aim literally at the ground and it is incredibly unsafe for me to drive at night with them like that.
    I know you're supposed to use a Vag-com to send a command so that they "re-learn" the new starting point, and then adjust the lights, but I have also read that if you do it while the car is off, it should be okay.
    Any help would be greatly appreciated, I don't have access to a Vag-com and I really can't afford to go to the dealer to pay 100 bucks for them to do it (though for safety I may in the end do this).
  2. 08-01-2012 07:28 PM #2
    Any ideas guys?
  3. Member 96AAAjetta's Avatar
    Jul 7th, 2008
    Ft. Bragg/Charleston S.C.
    2002 225TT
    08-02-2012 06:22 AM #3
    I adjusted mine with the ignition on, engine off. I did it at night with the lights on so i could see where they were being adjusted to. Worked out fine for me. They havent moved since.
    If a little's good, then a lot's better, and too much is just right.
  4. Member
    May 23rd, 2008
    Lewisville, TX
    2001 LZ7W 225 coupe; 2007 3.2 A3
    08-02-2012 09:33 AM #4
    there's a control module (that's what I call it) in driver-side wheel well. check and see it the "arm" is disconnected or broken. If so, both lights will point to the ground...about 6 feet in front of the car.
    in this pic, the "grayish" arm to the left of the black drop-link, is the xenon light leveler-arm. at the top, the arms connects to a lever....that little 2inch lever where the gray arm is connected, was broken on mine, and both headlights pointed directly to the ground. indy shop used some epoxy to temporary fix until the new module came in (about $60-80 as I recall.) Not cheap.
    anyway, check your as you may have same problem.
    cheeers
    You don't own a TT, you support it: 2001 LZ7W coupe; REVO chip; Forge hoses and DV relo; MadMax DV; Modshack VTDA; BlueFlame Catback, OSIR corners, Forge bling, H&R, Bilsteins, DEFCON2, 986 seats, 18in OZ Vela II; OEM TTQS alcantara steering wheel, knob, ebrake; OEM: BBS RS IIs; roof rack; trunk rack; phone bracket; trunk mat; all weather floor mats; 4-piece Votex kit. My Mods here: http://public.fotki.com/TTQ2K2/. 2007 3.2 S-Line A3.
