VWVortex.com - 2001 Golf GTi, 3071r, Pagparts, Bilstein, Eurodyne, Quaife LSD
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 40
    Thread: 2001 Golf GTi, 3071r, Pagparts, Bilstein, Eurodyne, Quaife LSD
    1. 07-30-2012 11:50 AM #1
      For sale is a 2001 Golf GTI. Around 170K on the chassis and odometer, around 60K on the AWW engine. Asking $4000 OBO.LOCATED IN NORTH FLORIDA
      Engine:
      Pagparts T3 log 3071R kit with around 38K miles on turbo + hardware, tuned to 1bar of pressure on Eurodyne Maestro (mafless, immo delete)
      ATW Small port head with 7K miles on it
      Godspeed FMIC
      Tial MVS 38mm wastegate (external dump)
      Tial 50mm V2 blow off valve
      630cc injectors
      Walbro 255 inline pump
      Metal water pump
      Manual timing tensioner
      New clutch master and slave cylinders and clutch hydraulic pressure lines
      Polished & mic'd camshafts & camshaft bearing surfaces.
      Silicon boost and vacuum lines.
      Compression test cold 185-195 PSI across all 4 cylinders!
      BKR7E plugs gapped to .28
      ARP Head bolts
      Head gasket ~2K miles old
      Coilpack harness ~2K miles old
      Custom 3" exhaust with high-flow cat from local shop Mandrel Bending Solutions
      Trans/drivetrain:
      APTuning built 02J with Quaife LSD, 02A solid keys, and other O2A bits internal that APTuning uses to upgrade the 02J box
      South Bend Clutch clutch kit and lightweight steel flywheel rated to hold 350 ft/lbs ~2K miles old
      Wheel bearings ~ 52k miles old
      Forcefed solid shifter bracket bushings
      Solid shifter end adjuster bushings
      APTuning spherical bearing dogbone mount
      VF Engineering drivers and passenger side engine mounts.
      Suspension:
      Bilstein PSS9 coilovers (this thing can get LOW)
      Powerflex polyurethan rear axle beam bushings
      Prothan front poly control arm bushings
      Powerflex steering rack bushing
      Balljoints ~32k miles old
      Tie rods ~32k miles old
      Strut mounts and bearings ~17k miles old
      S3 upper strut brace
      ~2K miles on new summer tires
      Body:
      Shaved rear bumper
      Hood has been stripped and painted with a VERY THIN coat of primer and paint. Already shows considerable scratches and needs a respray
      Newly-replaced drivers-side and passenger-side front fenders painted at a professional shop, although not well
      Wheelwell liners missing
      Front grill and bumper grills removed
      Rear emblems removed
      Interior partially stripped - no rear seats, seatbelts, carpet in the entire car. Only remaining internal bits is the roof liner, two front seats, front seat belts, door panels, sunroof controls, and dash assembly
      Tthis car has seen quite a bit of weather and wear and needs a full-body respray to look pretty. Of course, it's really meant to be a track car, so who cares?
      Issues:
      Front lenses are slightly fogged.
      A/C: Ice cold (34degF)
      Power steering is installed and functional!
      Dyno sheet/videos, Carfax are available upon request.
      Contact:
      elmoret at gmail
      Jul 15th, 2010
      03 A4
      08-05-2012 05:33 PM #2
      Trade?
    3. 08-06-2012 02:09 PM #3
      Quote Originally Posted by mk2gtig60 View Post
      Trade?
      PMed. Bump.
    4. 08-08-2012 10:28 AM #4
      bump
    5. 08-08-2012 11:32 AM #5
    6. 08-12-2012 05:25 PM #6
      bump
    7. 08-15-2012 07:13 PM #7
      bump.
    8. 08-17-2012 11:07 AM #8
      bump.
    9. 08-18-2012 05:40 PM #9
      bump
    10. Member
      Jan 27th, 2012
      Baldwin GA
      2003 Volkswagen Passat
      08-18-2012 06:01 PM #10
      Trade?
      138k on dash
      Sent from my Desire HD using Tapatalk 2
    11. 08-20-2012 11:08 AM #11
      Any upgrades? More information?
      Jan 27th, 2012
      Baldwin GA
      08-20-2012 03:22 PM #12
      Bunch of new OEM Parts, newer engine, Ice Cold A/C, Full Exhaust, Cold Air Intake, 7in Jensen Headunit, all new Memphis speakers, 13in acrylic shift knob.
    13. 08-21-2012 01:58 PM #13
      bump
    14. 08-22-2012 02:46 PM #14
      bump
    15. 08-26-2012 12:38 PM #15
      bump
    16. 08-28-2012 11:56 AM #16
      bump
    17. 08-30-2012 09:23 PM #17
      bump
    18. 09-01-2012 09:59 PM #18
      bump
    19. 09-02-2012 06:06 PM #19
      bump, price dropped.
    20. 09-05-2012 01:02 PM #20
      bump
    21. Member ohbe5's Avatar
      Dec 29th, 2009
      Carrollton
      97 A4 1.8t(sold), 01 Golf GLS 1.8T(sold), 91 MR2 BT
      09-05-2012 08:12 PM #21
      Holy crap that is dirt cheap! lemme know if you decide to part it out! GLWS
    22. 09-06-2012 01:03 AM #22
      Quote Originally Posted by ohbe5 View Post
      buy it and grab the parts off it that you want
    23. 09-06-2012 08:40 PM #23
      bump
    24. 09-10-2012 11:53 AM #24
      bump
    25. 09-14-2012 12:43 PM #25
      bump
