VWVortex.com - In for parts --> 2001 Audi All Road
    Results 1 to 18 of 18
    Thread: In for parts --> 2001 Audi All Road
    1. Former Advertiser
      Jan 24th, 2006
      39 Summer St. Paterson, NJ
      07-30-2012 11:58 AM #1
      2001 Audi AllRoad
      Engine: 2.7 Turbo
      Transmission: Automatic
      Please use reference # 105444 when sending a PM or calling.
      Thank you,
      AutoHaas
      888 897 2781
    2. Former Advertiser
      Jan 24th, 2006
      08-01-2012 04:32 PM #2
      ABS MODULEWITH PUMP 8E0614111AA 150.00
      AIR FLOW METER 2.7L 06C133471A 75.00
      ALTERNATOR 120 AMP 2.7L 85.00
      AXLE LH FRONT AWD AT 85.00
      AXLE RH FRONT AT AWD 85.00
      AIR BAH RH PASSENGER DASH 125.00
      AIR BAG LH DRIVER ROOF 125.00
      AIR BAG LH DRIVER SEAT 65.00
      AIR BAG LH DRIVER WHEEL 4 SPOKE 125.00
      RH AIR BAG LH PASSENGER ROOF 125.00
      AIR BAG RH PASSENGER SEAT 65.00
      AIR BAG LH REAR SEAT 65.00
      AIR BAG RH REAR SEAT 65.00
      CALIPER LH FRONT GIRLING DUAL 75.00
      CALIPER RH FRONT GIRLING DUAL 75.00
      CALIPER LH REAR 65.00
      CALIPER RH REAR 65.00
      COMPUTER AIR BAG 4Z7959655TB 115.00
      COMPUTER COOLING FAN RELAY 85.00
      COMPUTER CRUISE CONTROL 75.00
      COMPUTER HEADLIGHT RANGE CONTROL 85.00
      COMPUTER MIRROR MEMORY 4A0907445 100.00
      COMPUTER SUSPENSION ESP 4Z790738 300.00
      COMPUTER Suspension, TPMS 200.00
      COMPUTER SUSPENSION SELF LEVEL 300.00
      COMPUTER THEFT/LOCKING 4B0962258 100.00
      COMPUTER Transmission, 2.7L 175.00
      COMPRESSOR AC 2.7L 135.00
      CONDENSOR AC 2.7L,AUTO TRANS 125.00
      DOOR MIRROR LH BLACK AUTO DIM 125.00
      DOOR MIRROR RH BLACK AUTO DIM 125.00
      DASH BOARD PANEL 200.00
      DOOR WINDOW MOTOR RH FRONT 65.00
      DOOR WINDOW MOTOR LH FRONT 65.00
      DOOR WINDOW MOTOR LH REAR 65.00
      DOOR WINDOW MOTOR RH REAR 65.00
      ENGINE ACCELORATOR CONTROL 65.00
      ENGINE COMPUTER 2.7T AT 135.00
      ENGINE COOLING FAN BEHIND RAD 100.00
      ENGINE COOLING FAN FRONT OF RAD 85.00
      ENGINE !TESTED! RAN WELL 1250.00
      FAN BELT DRIEVN WITH CLUTCH 65.00
      FRONT BUMPER !CLEAN! 450.00
      FRONT DOOR SHELL BLACK LH 200.00
      FRONT DOOR SHELL BLACK RH 200.00
      FRONT DOOR WINDOW LH 65.00
      FRONT DOOR WINDOW RH 65.00
      FENDER RH SMALL DENT CHECK BEFORE 75.00
      FENDER LH,BLACK EXT,PAINT CODE 125.00
      FLYWHEEL A.T., 2.7L (turbo),2.7L 95.00
      FUEL Pump Assembly,2.7L 85.00
      FRONT DOOR REGULATOR LH 100.00
      FRONT DOOR REGULATOR RH 100.00
      FUEL TANK AWD 2.7T 200.00
      GRILLE UPPER 85.00
      HEATER AC CONTROLS w/o Nav sys 125.00
      HEAD LIGHT FOGGED RH COMPLETE 125.00
      HEAD LIGHT LH FOGGED COMPLETE 125.00
      HOOD BLACK PAINT CODE=LV9B 300.00
      INTAKE MANIFOLD (2.7L, turbo), 100.00
      IGNITION COLUMN WITH KEY AT 100.00
      LOWER A ARM REAR LH 65.00
      LOWER A ARM REAR RH 65.00
      LOWER TIE ROD REAR LH 65.00
      LOWER TIE ROD REAR RH 65.00
      LID TRUNK HATCH BLACK SMALL DING 225.00
      MASTER CYLINDER BRAKE 75.00
      POWER BRAKE BOOSTER 85.00
      LH,BLACK EXT,PAINT CODE=LV9B,5DR 400.00
      RH,BLACK EXT,PAINT CODE=LV9B,5DR 400.00
      QUATER WINDOW GLASS LH 125.00
      QUARTER WINDOW GLASS RH 125.00
      REAR BUMPER w/o prk assist 300.00
      RADIO AM-FM-stereo (w/cass & CD) 100.00
      REAR DOOR SHELL LH BLACK 175.00
      REAR DOOR WINDOW RH 65.00
      REAR DOOR REGULATOR LH 100.00
      REAR DOOR REGULATOR RH 100.00
      RADIATOR SUPPORT 2.7T AT 175.00
      STUB AXLE REAR HUB LH 85.00
      RH,STUB AXLE REAR HUB LH 85.00
      SPEEDOMTER MPH 2.7T !GOOD PIXELS 150.00
      STEERING PUMP 2.7L 85.00
      SPINDLE HUB LH FRONT 2.7L 85.00
      SPINDLE HUB RH FRONT 2.7L 85.00
      STEERING RACK 135.00
      STARTER 2.7L 85.00
      STRUT LH FRONT 150.00
      STRUT RH FRONT 150.00
      THROTTLE BODY 2.7L 078133062C 115.00
      TAIL LIGHT LH 100.00
      TAIL LIGHT RH 100.00
      TRANSMISSION !TESTED! ENY CODE 1000.00
      LH UPPER CONTROL ARM FRONT 30.00
      WHEEL 17x7-1/2 (alloy), 5 dual 100.00
      WIPER MOTOR FRONT WITH LINKAGE 60.00
      WIPER MOTOR REAR 65.00
      WINDSHIELD 5DR 100.00
    3. Junior Member dalejean's Avatar
      May 6th, 2004
      Rockford, IL
      2002 allroad 6-speed
      08-03-2012 07:03 PM #3
      Driver headlight $125
      Foglights & grills ?
      Oil Temp sensor ?
      Headlight washer T fitting (driver) ?
      Thanks,
      Dale McCormack
      Dale@TheMcCormacks.org
    4. 08-08-2012 03:20 PM #4
      pm sent
    5. Former Advertiser
      Jan 24th, 2006
      08-09-2012 12:01 PM #5
      Quote Originally Posted by dalejean View Post
      Oil Temp sensor ?
      Thanks,
      Dale McCormack
      Hello Dale,
      Thanks for the call!! Your order will be shipped asap.
      Quote Originally Posted by jdmfairlady21 View Post
      pm sent
      Replied!
      Thank you,
      Ramon.
    6. Junior Member Volks_Rado_G60's Avatar
      Mar 31st, 2003
      Jacksonville, FL
      08-19-2012 08:35 AM #6
      Pm sent. Please reply to woeppelm@gmail.com. Thanks.
    7. Former Advertiser
      Jan 24th, 2006
      08-20-2012 10:47 AM #7
      Quote Originally Posted by Volks_Rado_G60 View Post
      PM replied.
    8. Former Advertiser
      Jan 24th, 2006
      08-24-2012 08:33 AM #8
    9. Member pagvrt's Avatar
      Oct 15th, 2005
      chesapeake va
      90 JETTA COUPE 1.8T, 91 GTI VRT-RIP-. 00 b5 Passat 4 motion wagon2.7 swap. 00 B5 avant wagon
      08-24-2012 11:39 AM #9
      i need the hatch inner panels.... upper and lower..... with sun shade.....
      HBMOTORWERKS VW AND AUDI SERVICE AND PERFORMANCE.
      IN HOUSE FABRICATION...
      UNITED MOTORSPORT DEALER...
      https://www.facebook.com/HBMotorwerks
    10. Member Easywind's Avatar
      Oct 6th, 2007
      Western Pennsylvania
      2006 Passat 2.0t, , 1986 Vanagon Westy
      08-25-2012 06:40 PM #10
      Need foam insert for passengers side fender shipped to 15904
    11. Former Advertiser
      Jan 24th, 2006
      08-29-2012 08:24 AM #11
      Quote Originally Posted by pagvrt View Post
      The shade has been sold. And will you need the panels shipped ?
      Quote Originally Posted by Easywind View Post
      Sorry, these have been sold with the fenders.
    12. Junior Member
      Jun 2nd, 2012
      Bronx/Manhattan
      2001 Audi A6 2.7t
      08-30-2012 08:54 PM #12
      Willing to sell just the door fins?
    13. Former Advertiser
      Jan 24th, 2006
      09-04-2012 08:31 AM #13
      Quote Originally Posted by TurboToneNYC View Post
      Sorry, at this point we would like to keep them on the doors.
      Thank you,
      Ramon.
    14. Junior Member LUIGY's Avatar
      Mar 12th, 2009
      Golf Cabrio Mk1 87, Golf Gti Mk2 86, Audi Allroad quattro Biturbo 01
      09-06-2012 05:30 PM #14
      $$$$ lower center grill ship to 92154 thank you
    15. Former Advertiser
      Jan 24th, 2006
      09-07-2012 08:51 AM #15
      Quote Originally Posted by LUIGY View Post
      Hello,
      The lower center grille has been sold with the front bumper. Thanks for checking and hopefully we can help you with another part.
      Thank you,
      AutoHaas
    16. Junior Member
      Dec 27th, 2009
      Boulder, CO
      99.5 Audi A4 Avant 1.8TQM, 01 allroad 6MT
      09-10-2012 11:55 PM #16
      I need that switch, located next to the driver seat above the hatch button on the pillar shipped to 80304
    17. Former Advertiser
      Jan 24th, 2006
      09-11-2012 08:44 AM #17
      Quote Originally Posted by Avant Nate View Post
      I'm sorry, those switches have been sold.
      Thank you,
      AutoHaas
    18. Senior Member Capt.Dreadz's Avatar
      Jun 3rd, 2003
      Long Island, NY
      VRT's & 2.7T's
      10-03-2012 10:48 PM #18
      How much for the engine & how many miles on it?
      Everything VR6Turbo & Supercharged The world is ours!!
      Follow us on Instagram @ Everything_VR6turbo_SC
      FaceBook: Carlitus Christensen Sr. - Instagram: @ThatDreadLife - Twitter: @ThatDreadLife
