VWVortex.com - Brake fluid
    Results 1 to 2 of 2
    Thread: Brake fluid
    1. 07-30-2012 01:20 PM #1
      The other, friend of mine brought his 2000 Beetle 2.0 manual over, complaining about some brake vibrations.
      Drive the car, felt some slight vibration under light braking. Did a 60mph harder braking, when brake pedal 'fell to floor'.
      Pedal is firm when cold.
      Time for change out the brake fluid?
      Is the Beetle using standard (DOT 3, 4 or 5) or the special VW/Audi (expansive) stuff?
      When changing: Suck out with hand vacuum pump from bleeder on all 4 corners?
    2. Member vwbugstuff's Avatar
      Mar 27th, 2004
      NW Chicago 'Burbs
      2012 CC "R"-Line, 2003 Eurovan, 1979 Westfalia, 1978 Superbeetle Convertible, 1998 New Beetle
      08-02-2012 01:50 AM #2
      You might want to check the brake booster vacuum hose for cracks or leaks.
