Results 1 to 12 of 12
Thread: FS: 2004 Jetta TDI
  1. Member KubotaPowered's Avatar
    Jan 27th, 2005
    Tucson, AZ
    2006 Subaru WRX
    07-30-2012 01:24 PM #1
    I've had this car since 05 and it is time to move on, here it goes.
    The car is a 2004 TDI PD100 and has 140,000 miles on it with all services up to date. The timing belt, serpentine belt, water pump, bearings, rollers and seals were just replaced for the second time 6,000 miles ago. The brake pads and rotors were replaced 10k miles ago, and the engine oil and fuel filter were just changed yesterday. I always use Lubromoly 5w40 synthetic oil VW 505.01 approved. This car has installed, Hella joey modded ecodes with fogs, euro switch, rear fog, GLI rear tail lights, Evolution cold air intake, Rocketchip stage 2 software, 3 bar MAP, EGR delete, 3" turboback exhaust with cat shell, Eurojet FMIC kit, Garrett VNT1749 turbocharger, Boostvalve boost controller, Snow Performance water/meth, New South Boost and EGT gauges on the steering column, Audi TT short shifter, 42 Draft Designs shift bushings, Verdict Motorsports shifter bracket bushings, Southbend stage 3 clutch and single mass flywheel, H&R Cup Kit, Alt replica 18x9 et30 wheels, Continental DWS 225/40/18 with 10k miles on them, Neuspeed rear sway bar, Audi TT rear control arm bushings/polyurethane fronts, 42 Draft Designs interior LED kit. As for other maintenance, I have drained the power steering fluid and refilled with Pentosin CHF11S last year Dand the brake fluid was replaced with Ate Super Blue fluid. I also have a Black Stone engine oil analysis taken at 130,000 miles. I am asking $10,500 obo for locals, I will also consider trades i.e. MKIV GLI with cash going to the buyer depending on the vehicle. I wouldn't hesistate to drive this car across the country tomorrow. Please call or text for more information or pictures 715-761-1103. I hold the title to the vehicle and it has resided in Arizona it's whole life. It is a daily driver so it does have a couple minor door dings, 3-4 at the most.
    Quote Originally Posted by ..Derek.. View Post
    Clearly you aren't familiar with the "Golden Corrado". It's so clinically clean that in the event that you must urinate it must be done at least one zip code away in fear that it may catch a staph infection.
    Tucson Forced Induction
  2. Global Moderator Paul@VWvortex's Avatar
    Apr 2nd, 1999
    Sunny Chandler, AZ
    11 "Non-Sporty" TDI Golf, 11 Tiguan SE, TDi Tristar Syncro, 1980 Scirocco S "Der Ott"
    07-30-2012 01:38 PM #2
    Awesome car. I am sorry to see you listing it for sale.
  3. Member thirty-two's Avatar
    May 25th, 2007
    Phoenix, AZ
    07-30-2012 07:35 PM #3
    If you're interested at all in a trade + cash I'd like to make you an offer.
    http://forums.vwvortex.com/showthrea...white-on-BBS-s.
    Otherwise I'd like to buy it outright. Please PM me or give me a call, your inbox is currently full.
    Thanks!
  4. Member BLACKONBLACKGTI's Avatar
    May 24th, 2008
    Tucson, Az
    04 Gti 1.8t , 03 Audi A4 Quattro 1.8t, 96 Jetta VR6, 97 Ford F250HD
    07-30-2012 09:38 PM #4
    WOW!! didnt see that coming...if i had the cash flow, i would buy it in a heartbeat!! super clean
  5. Member xToaDx's Avatar
    Sep 26th, 2009
    Tucson
    E30
    07-30-2012 09:48 PM #5
    I see you on Sunrise on my way home from work sometimes.
    The car looks sweet!
  6. Member bc2240's Avatar
    Jul 23rd, 2008
    Tucson AZ
    07-30-2012 10:24 PM #6
    Its a really clean TDi. GLWS
  7. Member jhayesvw's Avatar
    Oct 3rd, 2001
    Tucson, AZ
    03 WRX wagon
    07-31-2012 12:04 AM #7
    this car is so perfectly cared for I cant believe its gonna go. Whoever buys it is getting a great car.
    Worth every penny and then some.
    Sep 11th, 2009
    PHX
    D3 A8L with all the fixins, 4door VR6T, Roofless VR6T, Vanagon, Passat Wagon,
    07-31-2012 04:11 PM #8
    maximize your dollar... list for sale in california
  9. Member stevedeezy's Avatar
    Oct 22nd, 2004
    PHX via SFO
    GLI, W220 & QX56
    08-02-2012 10:25 AM #9
    hmmm.....longer commute peaks my interest.
  10. Member boraIV's Avatar
    Jan 8th, 2001
    six.oh.two.
    '13 Cayenne Diesel, '08 Passat Variant 2.0T Stg 2, '81 ABA Caddy
    08-02-2012 01:47 PM #10
    this thing is sick! what kind of numbers does it put down? I have zero knowledge of TDIs
  11. Member jhayesvw's Avatar
    Oct 3rd, 2001
    Tucson, AZ
    03 WRX wagon
    08-10-2012 12:05 AM #11
    I think this car may be sold.
    Congrats John.
  12. Member KubotaPowered's Avatar
    Jan 27th, 2005
    Tucson, AZ
    2006 Subaru WRX
    08-12-2012 01:17 AM #12
    Forgive me Father for I have sinned. The car has sold and I am driving a 2006 WRX with the STI treatment.
    I got flamed for my dyno sheet on the TDI because after the gear correction I made the pulls in 3rd gear in order to not spin the dyno as fast, per the operator, and it cranked out 200whp and 325ftlbs with the alcohol injection. It was a great car for the 7 years I owned it
