VWVortex.com - C2Motorsports Handheld ECU Programmer and DTC Tool: C2NER
    Results 1 to 22 of 22
    Thread: C2Motorsports Handheld ECU Programmer and DTC Tool: C2NER
    1. Former Advertiser
      Jul 27th, 2010
      07-30-2012 03:00 PM #1
      First of all guys, if you have any questions about this awesome device don't hesitate to ask. This is a nifty way to flash on the go!!! No more sending in your ECU's...no...no. Just plug it up and let it work!!!
      The C2NER Handheld Programmer allows you the ease and comfort of flashing your own car in the comfort of your own driveway or on the go! Equipped with the ability to retain your OEM tune, the C2NER also allows you toggle between 2 additional programs as often and as many times as you want since they are stored inside the unit. Withour Buy 1 Get 1 FREE policy you will have a total of 3 files available to you: 1 stock and 2 performance. Also, not only does the C2NER flash your ECU, it allows you the ability to read and clear DTC codes that are stored on your ECU.
    2. 07-30-2012 08:00 PM #2
      does this allow you to remove the cel for sai?
      i got tuned at sowo this year by you guys, and didnt get the sai delete file, and of course 4 days later i start throwing sai codes! just my luck.
      03 silverstone GTI 24v
      EVOMS CAI, AWE exhaust, C2 race tune, Ultimos, BBS CH 18", h&r spacers, joey mod, black emblems, blacked tails, reiger illuminated shift knob/boot, 2 eclipse 12's
    3. Former Advertiser
      Jul 27th, 2010
      07-31-2012 11:34 AM #3
      Quote Originally Posted by vdub5818 View Post
      You can do just about anything with our C2NER!!!
    4. Junior Member
      Feb 12th, 2012
      Where the Navy sends me...
      '03 Jetta GLI, '93 Corrado SLC
      08-03-2012 05:22 AM #4
      I want to know more about the 2 performance settings. Your website doesn't say anything about the gains...
      -Holmes
      People are always surprised that my car smells of crayons
    5. Former Advertiser
      Jul 27th, 2010
      08-03-2012 08:43 AM #5
      Quote Originally Posted by Holmes741 View Post
      With a High-flow CAT and cold air intake you should get an estimated 15hp gain. Not only will your gain some power with our software, the overall drivability of the car will increase. You will noticed a better mid-range power, throttle response, etc.
    6. Member
      Sep 8th, 2007
      Felton, CA
      04 GTi VR6
      08-04-2012 01:29 AM #6
      So it's $250 for the tuner and $300 for 2 tunes right? Cuz they are buy one get one. Also, u guys have a tune to go with cams and hi flow cat?
    7. Former Advertiser
      Jul 27th, 2010
      08-04-2012 12:40 PM #7
      Quote Originally Posted by 04VR View Post
      That is correct man!!! Choose our RACE File if you have cams and a hi flow cat to tune your car!!! You should see around a 15hp gain and you will be surprised at how much better your car feels. If you have anymore questions just let me know, would be glad to answer them.
    8. 08-04-2012 03:50 PM #8
      Quote Originally Posted by Kurt@C2Motorsports View Post
      Im running the race file with just an intake and exhaust with no problems
    9. Former Advertiser
      Jul 27th, 2010
      08-04-2012 07:56 PM #9
      Great news!!! How are you liking it?
    10. 08-09-2012 08:02 PM #10
      it's great, really screams. Although just like just about every car nut, I WANT MORE! So if I did go with the tt cams, downpipe, hiflow cat I wouldnt need a reflash then right?
    11. Former Advertiser
      Jul 27th, 2010
      08-09-2012 08:45 PM #11
      No reflash necessary. The software will do the work.
    12. Member vwmaniac16vr6's Avatar
      Nov 17th, 2004
      North-west NJ 07838
      08-20-2012 09:23 PM #12
      how fast exactly can you switch maps (upload a flash) with the c2uner
    13. Former Advertiser
      Jul 27th, 2010
      08-22-2012 10:24 AM #13
      Quote Originally Posted by vwmaniac16vr6 View Post
      An average of 10 minutes. Not very long at all!!
    14. Semi-n00b
      Aug 7th, 2012
      lancaster pa
      2003 gli 24v vr6
      08-22-2012 08:19 PM #14
      on your website it says its only available for 12v not 24v is that true? im interested in it but i have a 24v
      Vralliance #206
    15. 08-23-2012 06:31 AM #15
      Will the C2 program get rid of the warm stall issue?
    16. Member boostperformance's Avatar
      Apr 8th, 2010
      North Canton, OH.
      2003 24v gti vr6 GT3582BB
      08-23-2012 08:36 AM #16
      Do you have turbo flashes available for my 24v? I am boosted with bosche 36lbs injectors and a GT3582R turbo.
    17. Former Advertiser
      Jul 27th, 2010
      08-23-2012 12:39 PM #17
      Quote Originally Posted by boostperformance View Post
      Yes we have turbo flashes available. Feel free to check out our site and if you have any questions let me know.
    18. 08-23-2012 04:46 PM #18
      I'm assuming the C2 flash won't fix the warm stall issue. If it does fix it, I'll buy one immediately.
    19. Member Brett VR6's Avatar
      Jan 29th, 2008
      Central NJ
      2002.5 VW Jetta GLi
      08-23-2012 10:41 PM #19
      If I delete my SAI and EGR can you guys theoretically set the system so when I get it inspected it says system ready? Reason I ask is I want to run the race tune when I get my TT downpipe but I live in NJ and they just check for check engine lights on OBD2 cars but the system they use also checks to make sure everything is ready. So it's kind of a catch 22
      Viva la C2!
      -Brett-
      02.5 GLI VR6 - TT DP/Testpipe, Autotech Cat-Back, Eurosport Cool-Flo, C2 Software, Raxles, Grounding Kit, Diesel Geek Sigma Shifter/Panzer Plate, Verdict Shift Bracket Bushings, ECS Bleeder Block/End Links, USP Braided Clutch Line, ECS/Gruven LW pulleys, Raceland Ultimos, 034 Strut Bushings/Motor/Dogbone/Subframe Mounts, R32/Poly Control Arm Bushings, Poly Rear Isolators, TSW Nur wheels, Yarrowsport Rear Bar, Euro Sport Cluster
    20. Former Advertiser
      Jul 27th, 2010
      08-24-2012 08:53 AM #20
      PM sent
    21. Former Advertiser
      Jul 27th, 2010
      08-29-2012 08:38 AM #21
      We are continuing to see an increase in the number of people ordering our C2NER!! Make sure you jump on the Wagen!!
    22. Former Advertiser
      Jul 27th, 2010
      08-31-2012 09:46 AM #22
      For the ones that have used our C2NER, how do you like it?
