Results 1 to 6 of 6
Thread: Exhaust cam mod
  1. Member bmxguy's Avatar
    Sep 17th, 2008
    PNW
    07-30-2012 04:58 PM #1
    I read a while back about someone who makes your exhaust cam actually runnable as a intake cam. Does anybody know this guys S/N on here? Still doing the exhaust cam mod? TIA.
    Quote Originally Posted by vdubspeed View Post
    This is the mk1 forum bro...we fix ****.
  2. Member 91JET16V's Avatar
    Jan 6th, 2012
    Tri Cities, WA
    1991 Jetta 16v, 1986 Jetta 8v, 1998 GTI VR6, 2003 GMC 1500
    08-01-2012 10:53 PM #2
    You can google it and it will pop up, I looked at it a couple weeks ago. Seems like the last post was from a couple years ago.
  3. Member 91JET16V's Avatar
    Jan 6th, 2012
    Tri Cities, WA
    08-01-2012 11:35 PM #3
    Pow! I happened to run across this in the 16v engine forum.
    http://forums.vwvortex.com/showthread.php?2508013
    Weeblebiker is the guys name.
  4. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    08-02-2012 12:51 AM #4
    He did ours, works very well.
    FS:Sunroof Deflector
    Sep 27th, 2010
    Quebec, Canada
    92 GTI 16v
    08-02-2012 11:42 AM #5
    no need of someone doing it for you, just cut the extension of the cam that drives the distributor , then install in the head and align the "dots" you are set to go, i cut mine with a bench top cutter, works really well , i dont know why he moves the dot on the cams and do all of these calculs, i always installed my 2 dots pointed at each others and never had any problem and i did it to at leat 5 cars.
  6. Member bmxguy's Avatar
    Sep 17th, 2008
    PNW
    08-02-2012 04:44 PM #6
    Quote Originally Posted by hantonyc View Post
    If the guy doing the modding to the cams changes where the gear is at to get it to work properly how could you say your works fine when it has to be ___teeth off. Anyways he was charging $100 and thats a screaming deal.
