Results 1 to 4 of 4
Thread: 16v Dizzy Hall sensor
  1. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    Megasquirt 3x Powered 98 Jetta GT 2.0
    07-30-2012 05:24 PM #1
    Where on the dizzy is the actual sensor? I see something right by the harness connector and another thing directly across from it. Which is it?
    98 Jetta 2.0 w/ Megasquirt 3/3x fully sequential
    ABA 16vT build thread
  2. 07-31-2012 04:08 PM #2
    The Hall Sender is inside the dizzy 180 degrees opposite from the point where the wiring harness plugs in on the side. On CIS-E Jetronic 16Vs the slotted wheel rotates to "signal" the KS control unit that the engine is running.
    This signal is only important if you are concerned that your fuel pump relay is getting a ground while the starter is turned over. Absence of a Hall Sender signal means no continuous ground to the fuel pump relay (i.e. you can crank 'till the battery goes dead, yet no start).
    Check the Bentley Manual to see where the CIS-E Jetronic fuel pump relay ground originates from if you are curious...
  3. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    07-31-2012 06:51 PM #3
    I only need it for cam position pulse. Need to know where to place the single pulse to activate sequential injection in megasquirt.
    Thanks! That is what I needed.
  4. 07-31-2012 08:11 PM #4
    I'm only triggering off the distributor, no crank sensor. I have mine set to "trigger return", 80 degree trigger offset, and falling edge.
    This is with the distributor adjusted somewhere in the middle which gives good rotor phasing.
    Hope that helps. One day I want to add a crank trigger and go sequential too. I was thinking of using the distributor for the cam position signal too.
