Closed Thread
Results 1 to 6 of 6
Thread: Need help? - Reading PA Area
  1. Member pocketrocket:R's Avatar
    Oct 4th, 2009
    Manheim
    2004 DBP R32 __________HPA\\\Ft-Blackjack___ _____________97 Jetta VR6_____
    07-30-2012 05:25 PM #1
    I am an ASE certified mechanic with over seven years experience in the import auto repair industry mostly working on Nissan/Infiniti and VW/Audi models. I have a fully equipped shop with all required tools and equipment including VAGCOM. Just looking to pick up some side jobs for some extra cash.
    Send any repair inquiries or questions directly to my inbox.
    Thanks
  2. Member pocketrocket:R's Avatar
    Oct 4th, 2009
    Manheim
    07-31-2012 06:32 PM #2
    Had a 1990 300ZX in the shop last week. Owner noticed low oil pressure readings and shortly after the motor seized and shot a few connecting rod bearings out the sides of the oil pan!! Found him a used engine in Philadelphia and got him back up and running !!
    After further inspection it became evident his clutch was on its way out so I went ahead and replaced that too!!
    I also discovered that his master cylinder was leaking brake fluid down the fire wall and onto the drivers side frame rail where it was starting to eat away at it. So I went ahead and took down the rust to bear metal with some scotch-brite pads on the section of rail, etch primed it and then sprayed it with under coat. Of course I replaced that faulty master cylinder as well!!
  3. Member pocketrocket:R's Avatar
    Oct 4th, 2009
    Manheim
    08-03-2012 10:16 AM #3
    Have a couple 1.8T's in the shop today.
    First is a 2004 GTI with an APR K04 kit and EIP front mount intercooler. Owner was driving when the timing belt slipped and left him stranded. After removing the head I found 12 bent valves. Luckily it caused minimal damage to the pistons just light surface scratches. Owner provided a used head that just needs the cams swapped over. Ordered a new timing belt kit with water bump and a completed head gasket kit. Get this one back on the street real soon!
    Second is a 2001 Golf 1.8T with an APR Stage 1 chip. Went and towed this one back to the shop from Albany NY. Owner complained of loss of power and an intermittent oil light coming on. After dropping the oil pan I discovered that a previous mechanic resealed the oil pan but when doing so he/she used way too much RTV. The bead of silicone dripped into the pan and eventually clogged up the screen on the oil pick up tube. Luckily there were no signs of engine sludge, crank play or worn bearings. I also removed the valve cover and was happy to find no sludge or worn cam lobes. I ordered a new pick up tube, fresh oil and a filter and this one should be running like a champ again!
    Thanks
    SELF MADE SOLUTIONS - MANHEIM PA
    My Build Blog
    Facebook.com/SelfMadeSolutions
  4. Member pocketrocket:R's Avatar
    Oct 4th, 2009
    Manheim
    08-07-2012 01:22 AM #4
    Just picked up this baby...
    I have some special and unique plans for this one!!
    More updates/details coming soon!!
    Thanks
    SELF MADE SOLUTIONS
    READING PA AREA
    Sent from my iPhone4 using Tapatalk
    My Build Blog
  5. Member pocketrocket:R's Avatar
    Oct 4th, 2009
    Manheim
    08-15-2012 02:15 PM #5
    Been very busy in the shop lately with new projects!! Promise to have more updates and pics up very soon!! Thanks for all the support!!
    Thanks
    My Build Blog
  6. Moderator nater's Avatar
    Apr 10th, 2000
    Downingtown, PA
    2008 Passat 4Mo 3.6L Wagon, 98 VRt, 2010 Routan/Caravan :)
    08-16-2012 05:11 AM #6
    You must be a paying advertiser to list products and services like these on the forums. Please contact us if that interests you.
Closed Thread
