VWVortex.com - Dielectric grease on coil pack?
    Results 1 to 12 of 12
    Thread: Dielectric grease on coil pack?
      Jul 25th, 2012
      Idaho | Arizona
      98/Jetta/VR6T-2.9L
      07-30-2012 06:41 PM #1
      Is it safe to put this on the coil pack? This is my third coil pack and these things royally piss me off. I don't know if its excess heat from forced induction parts that cause these to wear and crack more or what...however because of them its made misfire codes, burnt holes in my spark plug wires, fouled out my plugs, and now I have possibly related slight to moderate scoring in cylinder #6 and possibly #5 on a 5k mile engine...
      If this (used good condition replacement coil pack) goes within the year, I think I'm going with the GM coil conversion.
      On a side note...anyone have recommendation for any online spark plug wires; better and cheaper then steelerships OEM @ $110 a pop?
    2. Member dogyouare's Avatar
      Aug 9th, 2009
      Port Orange, FL
      90 Jetta GL, 91 Corrado G60, 96 Golf GTI, 88 300SE
      07-30-2012 08:07 PM #2
      yes its ok to put on coil. use it on the boot and plug. dont use it on where it has metal contact as this wont let it conduct electricity. if i was u i would do ford coil pack.
      Jul 25th, 2012
      Idaho | Arizona
      98/Jetta/VR6T-2.9L
      07-30-2012 09:46 PM #3
      your saying stay away from the actual inner metal connectors? i.e. not dumping it in the spark plug connectors itself like this...?
    4. Member masterqaz's Avatar
      Oct 4th, 2007
      Oakville Ont
      95 gti 24vt toy, 04 tdi golf economy, 94 gti 12vt sold
      07-30-2012 11:32 PM #4
      Its fine on the metal contacts in the plug boot. That is way to much though, Just a dab is all thats needed.
      diesel life cause cold feet are fun....
    5. Member izzo's Avatar
      Mar 19th, 2004
      ɐᴉɹɐƃlnq
      '96 Fiat Puntamera diesel
      07-31-2012 01:32 AM #5
      Quote Originally Posted by Tooled View Post
      Wires - OEM or Magnecor.
    6. Member
      Jul 25th, 2012
      Idaho | Arizona
      98/Jetta/VR6T-2.9L
      07-31-2012 01:57 AM #6
      i robbed this picture from google.....ford bronco....go figure...
    7. 07-31-2012 05:33 AM #7
      I decided to buy a set of MAGNECOR 8.5mm wires and i was instantly in love with the quality of these. I really do think that you pay for what you get with magnecor. A bit more pricey but i'm excited to see how long these wires last.
      Magnecor claims to be thee inventor of the electro-magnetically suppression spark plug wires.
      I read the Precautions statement and it strongly recommends not to use any kind of grease on the connector ends. I found that interesting but this subject requires more research. I haven't used any grease but i will wait later down the road to see if any corrosion appears.
    8. Member dogyouare's Avatar
      Aug 9th, 2009
      Port Orange, FL
      07-31-2012 01:21 PM #8
      Quote Originally Posted by MEGA 16v GLI View Post
      correct they dont want you to use grease because it burn through it or not conduct. like i say its only meant for rubber boot (or known as sealing point) so that imperfection will not allow water to get in (which will either short it or corrosion occur).
    9. Member dogyouare's Avatar
      Aug 9th, 2009
      Port Orange, FL
      07-31-2012 01:24 PM #9
      oh fyi ppl say u can use Vaseline (white petroleum) but they melt when they get hot( it ooze out or go into places u dont want to...). unlike die-electric they might melt little but they will keep their shape.
    10. Member
      Jul 25th, 2012
      Idaho | Arizona
      98/Jetta/VR6T-2.9L
      07-31-2012 01:42 PM #10
      great info and I'll be sure to checkout these plug wires.
    11. Member izzo's Avatar
      Mar 19th, 2004
      ɐᴉɹɐƃlnq
      07-31-2012 02:36 PM #11
      x2
      Mine, Magnecor blue silicone 8mm for VR6 coilpack:
    12. Member BumblebVR6's Avatar
      Nov 21st, 2001
      Houston, TX
      98 GTI VR6 / 05 A4(B6)
      07-31-2012 06:26 PM #12
      x3 Love my Magnecors
