Results 1 to 9 of 9
Thread: Running 20 pounds of boost on stock turbo?!?
  1. Junior Member
    Jul 15th, 2012
    Ewa beach
    2007 reflex silver gti
    07-30-2012 06:41 PM #1
    Only power adders I have are lightweight under drive pulley Volkswagen racing cai and apr stage 1 chip on 91 oct program on my mkv gti and under full throttle it peaks at 18-21 pounds of boost wondering if that's wrong or right and if wrong what steps do I need to do to control that thanks
  2. Junior Member Kurupt_hawaiian's Avatar
    Mar 30th, 2012
    Kapolei, Hawaii
    2010 2dr GTI 6MT/2007 Audi A4 2.0T 6MT
    07-30-2012 07:43 PM #2
    Stage 1 tune...seems to be the correct amount of boost.
    Elias
    MKVI GTI 2dr Deep Black Metallic 6MT
  3. Junior Member
    Jul 15th, 2012
    Ewa beach
    07-30-2012 07:49 PM #3
    Yea just got off the phone with apr and they said that's a few pounds over what they see normally but I shouldn't worry about it cause the tech stated he runs round 21-24 peak
  4. Member Domokun's Avatar
    Apr 5th, 2009
    Honolulu, HI
    08 GTI MKV
    08-03-2012 12:46 PM #4
    Quote Originally Posted by Snoyarc View Post
    I have APR S2 and I am boosting around 25 lbs. S1 numbers should be around 15-20.
    | 2008 ug gti mkv | team foreign objects | bsh | podi |
  5. Member AudiTypE-S4's Avatar
    Sep 26th, 2003
    Pearl City, HI
    B5 S4
    08-03-2012 07:17 PM #5
    Don't expect your turbo to last very long.
    2000 S4 Laser Red
    VAST | AWE | ER | STāSIS/alcon | VOGTLAND | JHMotorsports | RS4 OEM
  6. 08-03-2012 09:09 PM #6
    i have seen different boost gauges read different readings .. for instance if you tq the fitting on a new south boost gauge too much you will push the needle in to the vac side ..
    also even when you put the needle back to the middle i have still seen them read a pound or 2 higher than what the actual boost is ..
  7. Junior Member
    Jul 15th, 2012
    Ewa beach
    08-03-2012 11:16 PM #7
    Ordered a new forge diverter valve should help with some of the build up pressure
  8. 08-04-2012 02:11 AM #8
    pressure = power
  9. Junior Member
    Jul 15th, 2012
    Ewa beach
    08-04-2012 02:47 AM #9
    Agreed lol anyone have the nuespeed inlet piping kit and outlet as well ? Was thinking of ordering that as well
