Results 1 to 4 of 4
Thread: ECU Location on a 2002 Jetta TDI?
  1. 07-30-2012 08:15 PM #1
    I'm having a helluva time finding it, via the web or by tearing my dash apart (it's in pieces now). Any help would be GREATLY appreciated...
  2. Member Rockerchick's Avatar
    May 10th, 2005
    Cary, NC
    '03 BMP 20th GTI, '84 TD Jetta
    07-30-2012 09:22 PM #2
    I believe its in the rain tray. Passenger side IIRC.
    Quote Originally Posted by TM87 View Post
    VW-making mechanics out of owners since 1957.
    The project - '84 Jetta 1.6TD, 186k+, fully rebuilt, Giles IP and injectors, 2.5" custom exhaust, 51mpg
    Hers - '03 BMP 20thAE GTI, 125k, all stock...for now
    His - '01 Jetta TDI, 126k. Now has 3 pedals, as it should!
  3. Junior Member
    Aug 18th, 2000
    So. NH
    '00 Jetta '03 Jetta
    07-31-2012 09:19 PM #3
    open hood.
    remove the rubber from the cowel.
    You should remove the passenger wiper.
    Lift plastic and ecu is there.
    There are 2 rectangular connectors there is a slide piece that releases the conn from the ecu.
  4. Member
    Jan 10th, 2003
    Barrie,On.
    '05 Jetta TDI Wagon.
    08-01-2012 07:44 PM #4
    No need to remove the wiper arm, the ECU will slide right out of it's holder. You can ever get it out without removing the raintray (Although your hands take a bit of a beating)
