Results 1 to 11 of 11
Thread: Crankshaft Front Seal
  1. Member Skimmer0220's Avatar
    Oct 12th, 2009
    Delaware
    2000 Jetta VR6 12V
    07-31-2012 06:04 AM #1
    There's oil coming out of my crankshaft and being slung all over my engine so I figure my crankshaft seal is bad, now I want to replace it but don't have the tools to do it
    first off would an impact gun be fine to get the crankshaft pullley off? or would I need to buy a tool to brace the crankshaft pulley? also what about the harmonic balancer isn't there a brace need to hold that in place to get that off?
    second remvoing the seal is a screwdriver fine just to remove it? the tool to remove it is around $100-$200 and I don't really have the money for that right now, but someone near me may have it,
    and last installing the seal would a block of wood and a hammer be fine to tap it in? or would I need the tool to do this? I want to get this done while I have most of the stuff off the engine thanks!
    2000 Jetta VR6 BMW Chili Red
    VRSociety #322
  2. Member Skimmer0220's Avatar
    Oct 12th, 2009
    Delaware
    2000 Jetta VR6 12V
    07-31-2012 02:05 PM #2
    After lunch bump
    Sent from space through a satellite
    VRSociety #322
  3. Member Skimmer0220's Avatar
    Oct 12th, 2009
    Delaware
    2000 Jetta VR6 12V
    07-31-2012 08:34 PM #3
    No one? I tried searching and everything's for a 1.8t
    VRSociety #322
  4. Member Skimmer0220's Avatar
    Oct 12th, 2009
    Delaware
    2000 Jetta VR6 12V
    08-01-2012 06:40 AM #4
    Guess I'll be tackling this one blind
    VRSociety #322
  5. Member dogyouare's Avatar
    Aug 9th, 2009
    Port Orange, FL
    90 Jetta GL, 91 Corrado G60, 96 Golf GTI, 88 300SE
    08-01-2012 10:31 AM #5
    take pully off with impact.
    take the screw off to remove plate.( it bolts to block and oil pan)
    take flat head and hammer it out seal (dont score the wall)
    take new seal dab oil on it take flat wood and hammer it in. and re-install everything
    careful when installing over the crank. (a lot of oil helps to install)
    and get new crank bolt.
  6. Member Skimmer0220's Avatar
    Oct 12th, 2009
    Delaware
    2000 Jetta VR6 12V
    08-01-2012 11:37 AM #6
    Quote Originally Posted by dogyouare View Post
    ok great what about notching a hole in the piece of wood to get over the crank
    VRSociety #322
  7. Member dogyouare's Avatar
    Aug 9th, 2009
    Port Orange, FL
    08-01-2012 02:10 PM #7
    take the screw off to remove plate. (direction #2)
    then it just slide out.
    in this pic u can see the separation
    fyi u will see what i mean once u remove the crank pully
  8. Member Skimmer0220's Avatar
    Oct 12th, 2009
    Delaware
    2000 Jetta VR6 12V
    08-01-2012 02:32 PM #8
    I'm not to sure if I'm seeing the separation but from the other directions it sounds not as complicated as I was thinking, I ordered 3 seals so in case I mess them up when installing and I'll have to get the crank bolt too
    also once I take the pulley off I think I'll figure it out, I may start doing this tomorrow and is it necessary to remove the oil pan when doing this?
    VRSociety #322
  9. Member dogyouare's Avatar
    Aug 9th, 2009
    Port Orange, FL
    08-02-2012 12:22 PM #9
    no but u need to remove 5 screw closest to the crank pully. ok look at the pic do you see on the top its aliminum (it has the 5 screw hole which are the bolts u need to remove)
    now if u want u can remove oil pan and clean the oil pickup screen...
    any way here i found the pic. this plate is what ur going to see after u take the pully off. remove this plate and replace seal.
    where it mates to the block make sure u use high temp red rtv to seal!
  10. Member Skimmer0220's Avatar
    Oct 12th, 2009
    Delaware
    2000 Jetta VR6 12V
    08-02-2012 03:49 PM #10
    Ok I get it now makes complete sense I'm gonna try and tackle this tonight but won't be able to reinstall till tomorrow when I can pick up the crank bolt from the stealership
    Thanks for your help it's much appreciated
    VRSociety #322
  11. Member dogyouare's Avatar
    Aug 9th, 2009
    Port Orange, FL
    08-02-2012 04:04 PM #11
    NP GL
