Results 1 to 8 of 8
Thread: Car has a hard time starting when sitting for awhile
  1. Semi-n00b
    Jun 12th, 2012
    Quincy, MA
    2007 VW GTI (MKV)
    07-31-2012 09:49 AM #1
    I been noticing this lately. In the morning usually, when i turn the key to start the car (07 GTI 2.0 FSI)... it doesn't start right away. Once, I had to turn the key twice to get it going. I googled around and read that this might be battery related. So I ended up getting a new battery at autozone since the car is 5-6 years old now. I thought that would solve the problem but it didn't. Last night, I went to see the new batman movie. Car was sitting for about 3 hours, I tried to start the car and it struggled to start but ended up starting. 2 weeks ago, I got my fuel pump, cam shaft, cam follower replaced under warranty. So I'm not sure what's causing this.
    Edit: Also want to mention that the spark plugs are fairly new with only 2500 miles on em.
    Even did a vag scan on it:
    VCDS Version: Release 11.11.3 (x64)
    Data version: 20120401
    Tuesday,31,July,2012,09:20:15:22069
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
    VIN: ___________________ Mileage: 145420km/90359miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    0F-Digital Radio -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1C-Position Sensing -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    65-Tire Pressure -- Status: OK 0000
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 1K0 907 115 H HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0040
    Revision: 5BH14--- Serial number: VWZ7Z0F8162556
    Coding: 0403010A1C070160
    Shop #: WSC 01017 444 70027
    VCID: 2B5F3EAB8A1E111
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 043 C HW: 02E 927 770 AE
    Component: GSG DSG 070 1158
    Revision: 04507000 Serial number: 00000608190831
    Coding: 0000020
    Shop #: WSC 01279 785 00200
    VCID: 142D85573760AE9
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0021122
    VCID: 73EFE6CB12AE091
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
    Component: ClimatronicPQ35 090 0909
    Revision: 00090016 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 70E5E9C763B8329
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
    Component: Bordnetz-SG H46 1501
    Revision: 00H46000 Serial number: 00000006151033
    Coding: 978F8F214004150000140000001400000078770B1E0000
    Shop #: WSC 01424 444 82190
    VCID: 377712DB4656A51
    Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 300806 020 0501
    Coding: 00038805
    Shop #: WSC 01424
    Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
    Part No SW: 8E0 035 593 F HW: 8E0 035 593 F
    Component: SDAR SIRIUS H03 0120
    Revision: 00000000 Serial number: AUZ4Z7F3032676
    VCID: 2C5D3DB78F10169
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 62
    Mileage: 145401 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 09:46:41
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
    Component: 5L AIRBAG VW8R 034 8000
    Revision: 05034000 Serial number: 003B6D06ZBVU
    Coding: 0013644
    VCID: 6CDDFDB74F90D69
    Part No: 1K0 959 339 G
    Component: BF-Gewichtsens. 007 0007
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
    Component: J0527 034 0070
    Coding: 0012122
    VCID: 7AF1CBEF35C4789
    Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K6 920 973 A HW: 1K6 920 973 A
    Component: KOMBIINSTRUMENT VDD 1610
    Revision: V0003000 Serial number: VWZ7Z0F8162556
    Coding: 0007207
    Shop #: WSC 01287 785 00200
    VCID: 31632CC3A8327B1
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 H HW: 1K0 907 951
    Component: J533__Gateway H12 0150
    Revision: H12 Serial number: 3100106A1008F0
    Coding: 7F8F03600F000000
    Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 1K6 919 879 HW: 1K6 919 879
    Component: Kompass 001 0002
    Revision: 00001000 Serial number: 1225223T1KC402
    VCID: FDFB40F3A4EACF1
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 1610
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
    Component: Tuer-SG 005 0967
    Coding: 0001077
    VCID: 387511E74B48AA9
    1 Fault Found:
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    008 - Implausible Signal
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 L
    Component: EPS_ZFLS Kl.074 H07 1806
    Shop #: WSC 00000 028 00001
    VCID: 346D25D757204E9
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
    Component: KSG PQ35 RDK 051 0215
    Revision: 00051000 Serial number: 00000000000000
    Coding: 139006885103283E2904058FB0080A04889C00
    VCID: 74EDE5D717A00E9
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
    Coding: 0001076
    VCID: 397314E37042B31
    Address 55: Xenon Range Labels: 1T0-907-357.lbl
    Part No: 1T0 907 357
    Component: Dynamische LWR 0003
    Coding: 0000003
    VCID: F4ED65D797A08E9
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
    Component: Radio PM6 017 0021
    Revision: 00017000 Serial number: VWZ5Z7F2105922
    Coding: 0040402
    VCID: 244DD597E7C0DE9
    1 Fault Found:
    00877 - Treble Speaker Rear Right (R16)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 63
    Mileage: 145408 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 10:04:06
    Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
    Component: RDK 0420
    Coding: 0100101
    End ---------------------------------------------------------------------
    2007 VW GTI (MKV)
    Dec 29th, 2010
    Danvers, MA
    03 VW Golf(sold), 05 Jetta(sold), 09 Audi A3
    07-31-2012 10:32 AM #2
    If you let it stay for awhile - what is the voltage of the battery? Maybe alternator in not charging it properly. If it is not the alternator it could be that your starter is going bad.
  3. Semi-n00b
    Jun 12th, 2012
    Quincy, MA
    2007 VW GTI (MKV)
    07-31-2012 11:30 AM #3
    Not sure. I'll test the voltage next time.
    2007 VW GTI (MKV)
  4. Semi-n00b
    Jun 12th, 2012
    Quincy, MA
    2007 VW GTI (MKV)
    08-01-2012 02:02 PM #4
    My friend (hyundai tech) ended up helping me test my battery, alternator, and starter and he says those are fine... we're both really baffled on why this is happening in the morning. I wish I didn't live so far from him so he can test it for me while I leave it overnight.
    2007 VW GTI (MKV)
  5. 08-01-2012 07:15 PM #5
    Quote Originally Posted by webosb View Post
    i wish i didn't live so far from him so he can test it for me while i leave it overnight.
    slumber party!
  6. Senior Member JettaGT8V80's Avatar
    Jun 11th, 2003
    Waltham , Ma
    06 GTI UM Tuned
    08-01-2012 07:24 PM #6
    fuel filter or gunked up intake valves
  7. Semi-n00b
    Jun 12th, 2012
    Quincy, MA
    2007 VW GTI (MKV)
    08-04-2012 01:49 AM #7
    I'm starting to think it's the driver door latch that's causing this issue. I been turning the key to let the fuel prime (a couple of times) prior to starting in the morning and it seems to be working. And the vagcom scan shows an issue with the driver door too. Since the mk5 gti's driver door activates the fuel prime when opened... and I noticed when the driver door is opened, sometimes it shows on the MFD and sometimes it doesn't.
    2007 VW GTI (MKV)
  8. Member CorradoG602's Avatar
    Jan 22nd, 2007
    Framingham, Ma
    '07 chevy crew cab, Bobbed '81 XS650
    08-04-2012 08:09 AM #8
    Those door latches fail all the time. It's very very very common. I cannot tell you how many I replace in a week
    NEK Bobbed XS650 '07 Chevy Crew Cab
