Results 1 to 34 of 34
Thread: No power to ecu
  1. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    90 corrado with vr swap
    07-31-2012 11:45 AM #1
    It ran fine until this, it had a very low battery for the last week and I had been jump starting it. (I just got it running again and put back together) but I trickle charged the optima and now I have a nice and charged battery but now it won't start, I checked the 109 ecu relay, and the 18 load reduction relay. I did this by putting a wire on 30 and 85 on the relays and connected it to a battery, they both clicked but I'm not sure if that's the way you check them. Bottom line is I'm not getting power to pin 23 on the ecu connector and that's coming from the relay #3(109) so I need some ideas, the next move is to check and see if I'm getting power to the relay and if I am, I'm assuming my relay is toast. any input will be appreciated. Thankyou!
    Pics for clicks
  2. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    07-31-2012 03:14 PM #2
    UPDATE!!!! Did some checking and found that I'm getting a ground to pin 23 on j220 connector and that's sapposed to be a power when key is on. That would tell me I have a short to ground right?
  3. 07-31-2012 03:55 PM #3
    Does your RPM gauge move when cranking the motor over? Mine goes up to around 300 RPM
  4. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    07-31-2012 05:07 PM #4
    Yes it did, but not every time. I have no clue what is up! Would you possibly have a solution?
  5. 07-31-2012 07:08 PM #5
    Find the engines computer behind the firewall. Disconnect both battery terminals and then disconnect the wiring harness from the ECU. be observant and check for corrosion on both the pins of the ECU and the wiring harness plug itself. My car had similar problems to yours and it ended up being corrosion on the connection pins for the ECU. All i did was unplug and plug the ECU and my car suddenly started right up.
    I also used a little bit of dialetric grease on the pins with a small brush and then wiped any excess grease off and my car has been running like a champion ever since.
    This is just an easy (no cost) thing to try but its insane how simple a problem can be. I was absolutely shocked when i found this out. I also had condensation inside the ECU itself so i had to open up the case and let all the condensation dry out. I was thinking that i would have to replace the ECU but i decided it was worth a shot trying to dry out the ECU and it fixed all the stupid little problems i was having like the motor would cutout at around 4000 RPM. Its cool how i fixed my car without paying any money.
  6. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    07-31-2012 07:53 PM #6
    Ok well I'm going to open it up as soon as I can and check it out but I've been all over the ecu and then some, I've been back and forth and back again with checking continuity, I'm thinking a ground may be a culprit.
  7. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    07-31-2012 10:47 PM #7
    Anyone have any ideas?
  8. 07-31-2012 11:09 PM #8
    Does your pump prime when you turn the key?
  9. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    07-31-2012 11:10 PM #9
    Nope!
  10. 07-31-2012 11:15 PM #10
    i would try a new ign switch since your getting power to pin 23
  11. 07-31-2012 11:17 PM #11
    See if fuse 15 is blown
  12. 07-31-2012 11:17 PM #12
    Obd1 or 2
  13. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    07-31-2012 11:19 PM #13
    Obd 1 and I'm not getting power to pin 23, also all the fuses I checked and rechecked. They are all fine
  14. 07-31-2012 11:21 PM #14
    Nevermind you have a 109 relay so it 1. Check pin 6,9,38 and 54 with ign on let me know what you get and use a test light not a meter.
  15. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    07-31-2012 11:25 PM #15
    Ok pin 54 is battery and I do get power there the others are fuel pump, relay 109 #3 and the last # 38 is ignition power on and I have not checked these however if pin 38 does not have power would this tell me if my ignition switch was faulty? And also would this send signal to pin 23?
  16. 07-31-2012 11:29 PM #16
    yeah these pin except pin 54 are ign power so i am trying to figure out where is the problem. You try a different fuel pump relay? Test those pins and report back im off to bed.
  17. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    07-31-2012 11:32 PM #17
    Ok cool I'll let you know tomorrow and yes I tried another fuel pump relay and tried to jump it
  18. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    08-01-2012 09:35 AM #18
    Ok they all have power when key is on except pin 23, the fuel pump relay is still not kicking and I'm still not getting spark. I'm still getting a ground on pin 23 and that's not supposed to be, its a power supply. I think that's where my problem lies
  19. 08-01-2012 10:56 AM #19
    Change the ign switch
  20. 08-01-2012 10:57 AM #20
    And try a different 109 relay
  21. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    08-01-2012 11:05 AM #21
    I jumped the ignition switch and changed the relay along with the fuse block. The reason I changed the fuse block is because I was getting ground out on my red/blue wire and power in to pin 4 where power is supplied to the relay, I was thinking the fuse block was grounding out the 23 pin on the ecu I don't know what else to do I checked everything that I can think of and it's not the ecu because the problem is before it gets there
  22. 08-01-2012 11:39 AM #22
    Change the ign switch. Just unplug the old one and plug the new one in and use a screw driver to turn it.
  23. 08-01-2012 11:45 AM #23
    This car did not run for two years till i got there so i know a thing or two about the wiring. http://i476.photobucket.com/albums/r...0/061a101b.mp4
  24. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    08-01-2012 11:49 AM #24
    Okay I hooked up the fuse block when I changed it out I forgot to put in all the relays and fuses in. I don't know what I was thinking but I'm a get home and try to do that,as soon as I do I'll let you know what happens thankyou for your help!
  25. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    08-05-2012 08:17 PM #25
    Alright got the fuse block installed, still nothing but now im getting power to pin 23, still no spark or fuel pump priming I checked the pump. I need to replace the pump, however this does not mean it will run. I'm still lacking spark. I'm getting power and ground to the coil.
  26. 08-05-2012 08:47 PM #26
    Try an ign switch
  27. 08-05-2012 08:49 PM #27
    Also make sure your ground and positive wires are good at the battery
  28. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    08-06-2012 08:35 AM #28
    Ok I will replace the ignition switch along with the fuel pump and get back to you
  29. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    08-10-2012 11:09 PM #29
    Ok replaced ignition switch nothing and now my fuel pump is working but still not priming when ignition is on, no spark and my tack jumps to 3 thousand when cranking it could be my ecu, now I'm getting power to pin 23 when my ecu is plugged in only I tried another ecu and still nothing also broke them both open found a nuespeed chip in one, swapped em still nothing I'm ****in irritated wtf!!!!
  30. 08-10-2012 11:16 PM #30
    Pm me your phone number ill text you
  31. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    08-10-2012 11:17 PM #31
    It won't let me 8324099442
  32. Member 98GTI_VR6's Avatar
    Jan 21st, 2011
    Melbourne, FL
    1998 VW GTI VR6
    08-11-2012 01:17 PM #32
    make sure when u screw it back on its fully on and tight
    if nothing happens im gona say you need a new crank sensor!
  33. 08-11-2012 10:12 PM #33
    He figured it out bad ecu
  34. Member g6raddo's Avatar
    Sep 16th, 2004
    cypress, TX
    08-12-2012 01:10 AM #34
    Yes imma go ahead and replace the fuel pump, Bosch dizzy, and new knock sensor, and anything else I can think of
    Knock sensor
