Results 1 to 5 of 5
Thread: Unable To Communicate With Engine Skoda Octavia 2010
  1. 07-31-2012 12:40 PM #1
    Hi, unable to communicate with engine, comes up unable to communicate with control module... Gateway scan reads a malfuction... checked all fuses and battery voltage... see attached auto scan log... Its A 1.6tdi...
    Tuesday,31,July,2012,13:53:30:31184
    VCDS Version: Release 11.11.3
    Data version: 20120401
    VAG mobile
    Chassis Type: 7N0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: TMBJT21ZXB2044941
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine
    Cannot be reached
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.CLB
    Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
    Component: MK70 M MASR 0105
    Revision: 00H35001
    Coding: 0017665
    Shop #: WSC 73430 790 00999
    VCID: 7BFE07E63AFE411
    No fault code found.
    Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
    Part No SW: 3T0 820 047 M HW: 3T0 820 047 M
    Component: Climatic 150 0303
    Revision: 00006001
    Coding: 0000000002
    ASAM Dataset: EV_Climatic A01005
    ROD: N/A
    VCID: 3972DDEEB842B31
    No ASAM data for: "EV_Climatic" (VW36)
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08X-09.CLB
    Part No SW: 1K0 937 085 H HW: 1K0 937 085 H
    Component: BCM PQ35 B+ 104 0615
    Revision: 00104 AE
    Coding: 48180AB8A0050CB04010008011000024420000AE524D81605C 4440000040
    VCID: 346CECDA97204E9
    Subsystem 1 - Part No: 1Z2 955 119 D Labels: 1KX-955-119.CLB
    Component: Wischer 14091 26 0601
    Coding: 00D7B7
    2 Faults Found:
    01117 - Generator Terminal DF Load Signal
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 6
    Fault Frequency: 5
    Reset counter: 53
    Mileage: 33421 km
    Time Indication: 0
    Date: 2014.14.25
    Time: 08:08:29
    Freeze Frame:
    Term 15 On
    Voltage: 12.05 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    00978 - Lamp for Low Beam; Left (M29)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 1
    Fault Frequency: 38
    Reset counter: 38
    Mileage: 34402 km
    Time Indication: 0
    Date: 2020.14.23
    Time: 08:09:56
    Freeze Frame:
    Term 15 On
    Voltage: 14.00 V
    ON
    ON
    Term 50 Off
    OFF
    ON
    Address 15: Airbags Labels: 1K0-909-605.LBL
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: Q4 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PC1ZLW9H
    Coding: 0020788
    VCID: 3D7AC9FE646A8F1
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 521 BH HW: 5K0 953 569 C
    Component: LENKS.MODUL 009 0136
    Revision: FF010038 Serial number: 20100914101097
    Coding: 1080040000
    ASAM Dataset: EV_SMLSNGVOLWS A01004
    ROD: N/A
    VCID: 73EE2FC6DAAE091
    No ASAM data for: "EV_SMLSNGVOLWS" (VW36 *)
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 1Z0 920 903 M HW: 1Z0 920 903 M
    Component: KOMBI H04 0405
    Serial number: 00000000000000
    Coding: 410300
    Shop #: WSC 73430 031 00999
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: N/A
    VCID: 3F86B3F6A6669D1
    No ASAM data for: "EV_Kombi_UDS_VDD_RM09" (VW36 *)
    Address 19: CAN Gateway Labels: 7N0-907-530-V1.CLB
    Part No SW: 7N0 907 530 HW: 1K0 907 951
    Component: J533 Gateway H27 5603
    Revision: H27 Serial number: 060910F1001467
    Coding: E9801F0600020200002303
    VCID: EDDAB9BEF48A5F1
    1 Fault Found:
    00469 - Infotainment Databus in Single Wire Operation
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 34670 km
    Time Indication: 0
    Date: 2020.14.25
    Time: 08:33:04
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H04 0405
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: N/A
    VCID: EAD0B2A20D64489
    No ASAM data for: "EV_Immo_UDS_VDD_RM09" (VW36 *)
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.LBL
    Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
    Component: Tuer-SG 009 2120
    Coding: 0000564
    VCID: 4894A82A3BA8DA9
    Address 44: Steering Assist Labels: 1KX-909-14X-44.CLB
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 69 3001
    Revision: 00H17000
    VCID: 3162E5CEA8327B1
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.LBL
    Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
    Coding: 0000564
    VCID: 4796AB1636B6D51
    Address 56: Radio (J503) Labels: 5M0-035-1XX-56.CLB
    Part No SW: 1Z0 035 161 G HW: 1Z0 035 161 G
    Component: Radio-SWING 010 0033
    Revision: -----14S Serial number: SKZ4Z2K1310130
    Coding: 000002000001
    VCID: 3260EAC26D34409
    Tuesday,31,July,2012,14:14:03:31184
    VAG mobile
    Regards
    Calum
  2. 07-31-2012 02:32 PM #2
    Sorry engine code is CAY...
    Calum
  3. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    '10 Skoda Octavia vRS Combi / '67 Ford Mustang Conv.
    08-01-2012 07:30 AM #3
    Please download VCDS from our website again and reinstall it (no need to uninstall the old version), also take a look at your VCDS > Options screen if "Force K on Engine" is checked and make sure it is NOT checked/active. If that doesn't work contact me directly via email (Sebastian@Ross-Tech.com) please.
  4. 08-09-2012 08:33 AM #4
    Hi, worked fine with new settings, can get control module maps If you need them??
    Cheers
    Calum
  5. 08-09-2012 01:02 PM #5
    Hi trying to repair pressure sensor fault, checked wiring to sensor all fuses ok, replaced diffrential prtessure sensor, carroed out basic settings vcds said had been carried out ok... auto-scan below if you could shed some light on it please?? there is a few mvb at the bottom coolant temp was at 90 on scale cudnt see mvb for it...
    Cheeeers
    Calum
    09-Cent. Elect. -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 AG HW: 03L 906 023 AG
    Component: 1,6l R4 CR td H23 6930
    Revision: -------- Serial number:
    Coding: 00114014030500080000
    ASAM Dataset: EV_ECM16TDI02103L906023AG 003003
    ROD: EV_ECM16TDI02103L906023AG.rod
    VCID: 6BDE37A6829ED11
    2 Faults Found:
    7347 - Diesel Particle Filter; Differential Pressure Sensor
    P2453 00 [173] - Implausible Signal
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 53
    Mileage: 37539 km
    Date: 2021.14.13
    Time: 13:18:44
    7346 - Diesel Particle Filter; Differential Pressure Sensor
    P2453 00 [101] - Implausible Signal
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 37539 km
    Date: 2021.14.13
    Time: 13:27:30
    Readiness: 1110 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
    Revision: 00H35001
    Coding: 0017665
    Revision: 00006001
    Coding: 0000000002
    ROD: EV_Climatic_SK35.rod
    Cannot be reached
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Coding: 0020788
    Coding: 1080040000
    ROD: EV_SMLSNGVOLWS_SK35.rod
    Coding: 410300
    ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
    Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
    Coding: 000000
    ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Coding: 0000564
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Revision: 00H17000
    Address 46: Central Conv.
    Cannot be reached
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Coding: 0000564
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    17:49:03
    0 /min Engine speed 166
    0.00 hPa Particle filter; difference pressure 187
    10 Particle filter; field regeneration request status 188
    0.0000000 g Particle filter; oil ash volume 193
    80.02 hPa Particle filter; offset for differential press. 194
    25.30 g Particle filter; soot mass calculated 195
    9.09 g Particle filter; soot mass measured 196
    17:49:04
    17:49:42
    982 /min Engine speed 166
    17:49:49
    984 /min Engine speed 166
    17:50:10
    2571 /min Engine speed 166
